C Body brake swap questions... #615151
02/17/10 02:01 AM
02/17/10 02:01 AM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
Will the front disc brakes from a 71 Chrysler 300 interchange with a 68 300? A friend has a 4 wheel drum 68. I parted out a 71 last summer and saved the upper control arms, knuckles, rotors, calipers and lower control arms. I also saved the power booster, MC and prop valve...
Re: C Body brake swap questions... [Re: Kern Dog] #615152
02/17/10 07:07 AM
02/17/10 07:07 AM
Manistee, Michigan.
High Impact Offline
High Impact  Offline
Manistee, Michigan.
They should work fine, I replaced the 4 piston Caliper disk's on my 67 Sport Fury with a single pistion set off a 72 New port. Their on but thats as far as I;ve got as I need to put the motor back in sometime this winter. Your buddy should have no problem.
Re: C Body brake swap questions... [Re: High Impact] #615153
02/17/10 10:50 AM
02/17/10 10:50 AM
Andrewh Offline
Andrewh  Offline
I agree. 65-73 all are compatible.
Should only need the spindles and calipers. upper and lower control arms are the same.
Ball joints should be the same as well.
Re: C Body brake swap questions... [Re: Andrewh] #615154
02/17/10 12:54 PM
02/17/10 12:54 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
My 66 300 had 70 C body spindles, rotors, calipers and caliper brackets.
Re: C Body brake swap questions... [Re: Lefty] #615155
02/17/10 02:52 PM
02/17/10 02:52 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
Yes it did and I remember it well Lefty....
Re: C Body brake swap questions... [Re: Kern Dog] #615156
02/17/10 08:11 PM
02/17/10 08:11 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Thanks guys. My friend will be pleased to hear the good news.
