Re: 70 B BODY GLOVE BOX DOOR
[Re: DAYCLONA]
#614108
02/15/10 06:32 PM
02/15/10 06:32 PM
Posts: 31 Iowa
70B Body
Iowa
Here's a picture of where the tab that needs to be pushed is.If I remember right key needs to be in lock and turned,with the tab pushed it should just pull apart.
1970 Satellite 383/AT
[Re: 70B Body]
#614109
02/15/10 07:31 PM
02/15/10 07:31 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Our Savior, I'm going to have that pic tatoo'd on my arm for future reference,....Thanks Dan!
[Re: DAYCLONA]
#614110
02/15/10 07:49 PM
02/15/10 07:49 PM
Posts: 31 Iowa
70B Body
Iowa
Can't take all the credit.It's a picture I got from my savior years ago when I had the same problem.I forgot who it even was its been so long. Just always kept the picture.Hope it works for for you.And keep the picture handy because I'm sure it will come up again.
[Re: 70B Body]
#614111
02/15/10 08:48 PM
02/15/10 08:48 PM
Posts: 3,519 Lansing, MI
70gtx440dana
Lansing, MI
Any way to get these out if you do not have the key that operates the lock? I have several I would like to disassemble.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: 70gtx440dana]
#614112
02/15/10 09:19 PM
02/15/10 09:19 PM
Posts: 70,126 Here
DirectSubjection
Tacohead. The First and Only
Here
Here's a full thread on it from the archives. https://board.moparts.org/ubbthreads/show...&PHPSESSID=Once you get the gist of it, you can pop them right out. I found out not all latch mechanisms are interchangeable.
Ride eternal, shiny and chrome
[Re: HEMI ROY]
#614115
02/15/10 11:51 PM
02/15/10 11:51 PM
Posts: 898 iowa
copchaser
iowa
First of all, you do not need the key in order to take the lock a part. You'll have to monkey around with the spring thing on the side, and use a small screw driver on that tab on the side, it will come right apart. Bring it to me and I'll have it apart in a couple of minutes. Untill you figure out the trick, it drive you nuts, maybe even postal. Good luck.
