tunes in your vintage Mopar.......what are you using?
#61339
05/22/08 12:08 AM
05/22/08 12:08 AM
Posts: 14,479 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
how about some pics and details of what you're running for car audio in your classic Mopar.
i'm in the process of putting my heap back on the road, and while i enjoy the sound of a healthy V8 as much as anyone......i kind of like to have the stereo cranking if i'm going any distance at all.
what are you guys using, and how much hacking did you have to do to install it?
Re: tunes in your vintage Mopar.......what are you using?
[Re: fast68plymouth]
#61340
05/22/08 12:46 AM
05/22/08 12:46 AM
Posts: 4,574 Upper Midwest
Black_Sheep
Upper Midwest
Stock AM/8 Track with 3 speaker dash. The radio has been upgraded with an MP3 player jack and better speakers, the "system" sounds pretty good for what it is...
'69 Plymouth GTX See you on the street...
[Re: Jim_Lusk]
#61345
05/22/08 11:35 AM
05/22/08 11:35 AM
Posts: 2,928 Canada
RobR
Canada
[Re: RobR]
#61346
05/22/08 11:47 AM
05/22/08 11:47 AM
Posts: 858 Oklahoma
silverfish
Oklahoma
I never really listen to the tunes but I put some in for my son..(I'm too busy listening for parts falling off)
Is it just me or is something missing in this picture just to the right of the brake pedal???
[Re: silverfish]
#61347
05/22/08 12:02 PM
05/22/08 12:02 PM
Posts: 3,358 Berwyn, IL
challenger70
Berwyn, IL
I have an Eclipse head unit with Boston Acoustics speakers (3.5" in factory location and factory grilles) on the dash and 6x9 in the package tray. 2 Rockford Fosgate amps one for the sub one for the interior speakers and a JL Audio 10" Sub in the trunk. From inside/outside all you can see that is out of norm is the little red "Boston" on the speakers through the grills(if you really look) and the aftermarket head unit in the factory spot. But turn it on and it sounds unbelievable for a 40 year old dodge and puts most new cars to shame.
[Re: silverfish]
#61349
05/22/08 12:16 PM
05/22/08 12:16 PM
Posts: 2,928 Canada
RobR
Canada
For some unknown reason my orig gas pedal wore out and broke I scored a new NOS pedal with the decor trim and I don't have the matching brake and clutch to go with it so I didn't put it in...
#61351
05/22/08 01:02 PM
05/22/08 01:02 PM
Posts: 871 WA 98043
thecarfarmer
WA 98043
A buddy of mine had a stock AM in his '66 Coronet 500 with an FM convertor stashed in the glovebox. Worked for him.
For my pickup ('54), I've got a bunch of pretty good stuff (that's several years out-of-date, but was high end at the time).
Eclipse 5303 head unit for the glovebox (which works okay since the glovebox is in the middle of the dash, and the head unit comes w/ a remote).
I also have an old 10" MTX sub that I may try to make an under-seat enclosure for, or just upgrade to a newer style subwoofer with a lower 'q' factor that works in a small box, depending on whether I can get a big enough box stuffed under there.
I'll re-use my Aura component drivers. Best sound I could find (at the time) in the under-$1K speaker market - and I listened to the Diamond, Quart, etc. offerings.
Unfortunately, (due to theft) I don't have my 3 way 24 dB crosssover; I'll have to get another crossover - I'm a big fan of separate amps for tweeters and mids.
Advice: spend as much as you can afford on the mid and tweeter speaker drivers - they're where the magic is. If you go for coaxials, ones that have an aim-able tweeter are preferable. If they aren't set up to be bi-amped, cut the leads off the tweeters, and put some separate leads on 'em so you can run them from a separate amp. Subs aren't such a critical item - they've received SO much R&D over the last fifteen years that even relatively cheap ones are pretty good. A single 10" or 12" is usually sufficient for musical reproduction (and even moderately high-power BOOM) in a typical '60's sedan). Since I got out of the scene a few years ago, there's been a lot of work spent on getting a lot of sound out of a small speaker enclosure (one that won't eat your trunk).
Most passive crossover sets (ones between amp and speaker) are CHEAP, and most tweeters are crossed over at too low a frequency; this leads to 'spitty' vocals (especially female voices) at higher volumes) - active (between the source and the amps) crossovers and separate amps solve a lot of this.
Subwoofers are really important to musical reproduction. A lot of kids go overboard on them, and neglect the rest of the equation (BOOM, BOOM, BOOM, while the licence plate frame and trunk lid buzz...). One of the best - and many of the worst - sub setups I've heard were 'bandpass' subs. Off-the-shelf stuff is basically hit-or-miss here; usually the latter. Bandpass boxes should be custom tailored to the sub and car. A musclecar-era car is a great candidate for one, however, since there are often speaker cutouts in the parcel deck under the rear window where the sound can come thru. For myself, I'd build an enclosure onto the bottom of the package deck to mound a sub in a BP box to feed thru there. It'd save some trunk space; you'd hardly see it with the trunk open - but just a single driver tucked up towards the front of the trunk will suffice, as long as you have speaker grills in the package deck to allow the sound in.
Buy amps bigger than you need (i.e. 60-100 watts per channel for speakers that you'll run at 30-50 watts); turn the gain down a little, and you'll have tons of headroom. Also, you don't need high-end amps for casual listening. The little tiny bit of sonic nuance you'll pick up by going to a high end amplifier will be lost as soon as you fire the car's engine (ask how I know).
Buy a head unit based on features you like; they all have CD drives and tuner packs that are way better than you'll need - any $100 name brand unit is going to be fine. Go shopping at the stereo store and pick which one you'll like to use.
Also, unless you're running a really big bass amp, I wouldn't run out and put stiffening caps on its input. Any decent quality speaker wire and power wire should suffice - there is VERY little to be gained there other than making sure the conductors are sized appropriately to the power load.
Probably a little "TMI" for your question; if so, here's what I'd leave you with: Allocate half the budget to your speakers; choose a radio based on the features you like.
Good references: Car Stereo Review Magazine, crutchfield.com
-bill
Seduce the attractive, and charm the rest.
489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
[Re: RobR]
#61352
05/22/08 02:38 PM
05/22/08 02:38 PM
challenger70
Berwyn, IL
What mounting points did you use for the amp you mounted on the rear sear brace? Factory holes or did you drill? I had the same idea for my Challenger but there wasn't quite enough room to get at it easily. I plan on doing that once I get to that point with the Charger though. Nice clean install.
#61356
05/22/08 07:57 PM
05/22/08 07:57 PM
Posts: 3,387 Toronto, ON
Shakey
Toronto, ON
Turnswitch took my AM radio, added an FM tuner and an MP3 jack without changing the stock look.
1969 Dodge Charger R/T SE - 440 AUTO
[Re: HemiStan]
#61359
05/22/08 09:51 PM
05/22/08 09:51 PM
Posts: 3,535 Canuckville
68Cbarge
Canuckville
.."breaker,breaker one-nine.. negatory on the jukebox,I am usually 10-8 on the side hunting for bears on my vintage 23 channel CB.. I got my pedal to the metal and I'm east bound hammer down..... 10-4 and all the good numbers to ya good buddy.Keep your britches between the ditches. This is 318 and I'm waving a hand back at ya! 10-4 and I'm gone!"
'68 Newport Custom Barge on a Budget!! BOAB 1973 Satellite WAGON! 318- 3 on the tree!! 2008 Chrysler 300c HEMI!
[Re: challenger70]
#61363
05/23/08 11:04 AM
05/23/08 11:04 AM
Posts: 2,928 Canada
RobR
Canada
challenger70 I think I just drilled...I think there were two holes at the top that I used but the bottom for sure had to be drilled... I'd have to go out and look to be a 100%... Thanks for the complement
[Re: RobR]
#61364
05/23/08 07:24 PM
05/23/08 07:24 PM
Posts: 902 Bellevue, WA
Blackwidow69
Ring Knocker
Ring Knocker
Bellevue, WA
I posted a couple of pictures of mine back in a thread from sept 2007. Hopefully this link will work for you. https://board.moparts.org/ubbthreads/show...art=1&vc=1.Not sure if you are looking for a hidden deal or a new type of radio in the existing radio hole. It wasn't that hard to fashion up a piece of sheet metal to use the existing radio holes and clamp the radio body to. Then the plastic face plate to cover the sheet metal plate I cut out of one side of my calipers storage box. Pattern looked pretty similar to vinyl really. Good luck with yours. Todd
1969 Ply Roadrunner, 383 4-speed on street tires.
3,830 lbs race weight.
Best 1/4: 13.1 @ 106.83
440 & overdrive 4 speed going in.
2005 Power Wagon 35X12.5 KM2's
[Re: Blackwidow69]
#61367
05/23/08 10:42 PM
05/23/08 10:42 PM
fast68plymouth
So. Burlington, Vt.
this is sort of what i have in mind. thanks for the pic and link.
[Re: 63stabamatic]
#61370
05/24/08 10:25 PM
05/24/08 10:25 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Dual flowmasters make my tunes.
[Re: Supercuda]
#61371
06/02/08 11:09 PM
06/02/08 11:09 PM
70Fish
I was searching for audio threads and found this one. I just had a Kenwood CD player and 4 speakers installed in my 68 Dart. Sounds great, but after running it for a bit, there's a faint smell of something burning, I think. When you turn the power off, the smell goes away. [Edited by Moparts - Keep it clean], I'm worried something's now cooking under the dash! Should my head unit with no amps can be wired directly under the dash to the ignition switch/power or should it have gone to the engine bay on the relay? Thanks!
'70 Barracuda
'94 Harley Davidson FXDWG
Pit Bull named IKE
#61372
06/02/08 11:28 PM
06/02/08 11:28 PM
Posts: 16,453 Canada
CrAzYMoPaRGuY
Canada
That's odd, I'm searching for a two-shaft stereo as we speak.... I can't seem to find good ones anywhere, I take it they aren't made anymore. I guess I *could* toss a new style deck in, but I don't want to if I don't have to.....
CrAzYMoPaRGuY
[Re: mkdart]
#61376
06/03/08 10:43 PM
06/03/08 10:43 PM
70Fish
Sounds are a must in my ol' Dart since she's only got a slant 6 in her to listen to!
Any recommendations on wiring the power wires under the dash vs directly to the starter relay? If going to the starter relay, is there some sort of fuse used in-line? Thanks!
'70 Barracuda
Pit Bull named IKE
[Re: 70Fish]
#61377
06/03/08 10:59 PM
06/03/08 10:59 PM
Posts: 824 NH
72challorange
He's Game
He's Game
NH
I used a Sony Head unit with Ipod cable. I have the cable in the Ash tray for the Ipod. I made the box from some scrap plywood nd some carpet from the parts store. Sounds good. I put some small speakers back in the doors since they had holes already. Added some power lock solenoids while I was in there. That is the red light in the blank guage. Tom By tdavist, shot with DSC-P72 at 2008-06-01 By tdavist, shot with DSC-P72 at 2007-12-08 By tdavist, shot with DSC-P72 at 2008-04-10
