Re: Flywheel and pressure plate hardware
[Re: chargersNW]
#613356
02/14/10 04:44 PM
02/14/10 04:44 PM
Challenger 1
Cincinnati, Ohio
I work for a company that produces flywheels. We will not warranty and damage caused from using grade 8 bolts. They do not have the shear strength of hardened pressure plate bolts. Corect hardware is available at any auto parts store.
Dustergirl, I'm thinking the bolt heads stick out too far anyway?
[Re: chargersNW]
#613357
02/14/10 06:06 PM
02/14/10 06:06 PM
Posts: 22,873 Chicken coop
dustergirl340
Chicken Little
Chicken Little
Chicken coop
That's one big problem, our only good local auto parts store shut down. I'm stuck with Advance/Auto Zone until I find a NAPA in a neighboring town. I'll just get the bolts through Brewers since I need a couple other parts there anyway.
thanks guys
[Re: dustergirl340]
#613358
02/14/10 06:12 PM
02/14/10 06:12 PM
Posts: 10,549 Rittman Ohio
fourgearsavoy
Rittman Ohio
You really need to have the correct bolts and washers for your application.Wayne should be able to help but I know Mancini's has the MP kit in stock. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: 70duster340]
#613363
02/14/10 10:49 PM
02/14/10 10:49 PM
fourgearsavoy
Rittman Ohio
I don't trust lock washers I have seen too many of them split.I will use an AN series flat washer and red Lock-Tite when I need something to stay in place Gus
