A body ralleye dash #613157
02/14/10 12:12 PM
02/14/10 12:12 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
..is it possible to just re-wire the rotary connector to the ralleye bezel when converting from a standard dash or are there other issues?
The trick is to control your hobby and not have your hobby control you...pretty hard to do!
Re: A body ralleye dash [Re: can.al] #613158
02/14/10 12:33 PM
02/14/10 12:33 PM
70duster340 Offline
70duster340  Offline
If I remember correctly, after much research and help from members here, that's what I did. Mine isn't installed and functional yet, and I'm sure some more knowledgeable members wil chime in soon.
Re: A body ralleye dash [Re: can.al] #613159
02/16/10 07:27 PM
02/16/10 07:27 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
my understanding is that the dash itself is different, and that you can't easily just mount the rallye cluster in a non-rallye dash.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: A body ralleye dash [Re: GO_Fish] #613160
02/16/10 07:38 PM
02/16/10 07:38 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
The Std dash frame is Different!!!
Re: A body ralleye dash [Re: GO_Fish] #613161
02/16/10 07:39 PM
02/16/10 07:39 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Yes, the dash frame is cut different, but you can make your harness work.
Re: A body ralleye dash [Re: Jim_Lusk] #613162
02/16/10 10:15 PM
02/16/10 10:15 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
..tx all
i have correct steel frame and gauges.
would like to use my existing harness if possible.(Duster)
