8 3/4 a body green bearings #613059
02/14/10 11:10 AM
02/14/10 11:10 AM
Canada
Dons Dart Offline OP
Canada
To install green bearings on my axels does one have to remove the thrust buttoms in the dif .My case is a 849 open with 323 gears.
Re: 8 3/4 a body green bearings [Re: Dons Dart] #613060
02/14/10 11:29 AM
02/14/10 11:29 AM
scratchnfotraction Offline
when I did mine,I asked Moser about it
they said the 489 with the block in would be ok to run it...
I ran it 8 yrs or so and never a problem out of it,daily driving aleast 90 miles a day
I swaped to a 742 open and took a cold chiesle to the block and broke it in 3 piece and removed it
ran about a yr or so,then had a green bearing go out and start leaking oil
replaced the greens and run it with out the axle tube seals this go round as well...
o-ring on the bearing seals the tube up
so.IMHO..either way will work and end seals are not needed either
but the axle seals are a double protection on the ends against leaking
you have to remove the carrier and ring gear to remove the cross pin IIRC
some do ...some dont...up to you
Re: 8 3/4 a body green bearings [Re: scratchnfotraction] #613061
02/14/10 11:39 AM
02/14/10 11:39 AM
I also give this idea I have on the bearing failure...
they dont take side loading well from what I have read and been told...
mine was pushing 8-9 yrs at 90 miles a day
I hauled a tow dolly about 200 miles,it had a fishtail motion when empty
wagged my truck the 200 miles back and forth all the way till loaded then towed it like on glass..real smooth and no fishtailing
I think the back and forth did the bearing in, cause of the side loading back and forth
it was bad enuff empty to slow me down from 60 to 45 mph
couple days later it was leaking
I have done lots of hard cornering,dough nuts,power slides,and just plane hammering on it
I think the 200 miles of steady back and forth side loaded them enuff to wear the 8-9 yr old bearing out...
just my experiance with them
my new set is working fine and no leaks with just the o-ring on the bearing...no axle tube seals in this go round
Re: 8 3/4 a body green bearings [Re: scratchnfotraction] #613062
02/14/10 01:53 PM
02/14/10 01:53 PM
Canada
Canada
still lost why does that thrust buttom have to come out.Are all 8 3/4 pumpkins have this buttom.
Re: 8 3/4 a body green bearings [Re: Dons Dart] #613063
02/14/10 02:58 PM
02/14/10 02:58 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
If you are running stock length axles with snap-ring style Green bearings, the thrust button does not need to be removed.
Re: 8 3/4 a body green bearings [Re: DoctorDiff] #613064
02/14/10 03:42 PM
02/14/10 03:42 PM
Canada
Canada
Thanks Dr Diff over on FABO they all say call you for price and advice.I am running stock shafts.Not sure to go with OEM bearings or the green bearings.with thoes snap ring bearings how does one install it. any pics on instalation.Thanks.If yoiu like you could e mail me with prices. babyboo_cin@hotmail.com
Re: 8 3/4 a body green bearings [Re: Dons Dart] #613065
02/14/10 05:01 PM
02/14/10 05:01 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
..heh Don.
..some say the green bearings don't handle axial or lateral loads as well as oem,personally i have no experience with them.
why not just use oem,or do green bearings have some advantage?
Re: 8 3/4 a body green bearings [Re: DoctorDiff] #613066
02/14/10 05:57 PM
02/14/10 05:57 PM
Groningen, the Netherlands
4doorSatellite Offline
if you use the conventional green bearings you will have to remove the thrust button?
Re: 8 3/4 a body green bearings [Re: 4doorSatellite] #613067
02/14/10 06:01 PM
02/14/10 06:01 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I don't know if you must remove the thrust button with the first generation, RP-400 Green bearings.
I don't see any reason to run the RP-400 bearing still sold by Mopar Performance.
Re: 8 3/4 a body green bearings [Re: DoctorDiff] #613068
02/14/10 06:05 PM
02/14/10 06:05 PM
Canada
Canada
Hi Al if you run the green bearings there is no worry about the axel end play.OEM bearings there is an adjustment for the axel.
Re: 8 3/4 a body green bearings [Re: DoctorDiff] #613069
02/14/10 06:56 PM
02/14/10 06:56 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Re: 8 3/4 a body green bearings [Re: MoparforLife] #613070
02/14/10 08:52 PM
02/14/10 08:52 PM
Canada
Canada
What does this snap ring look like.also what does it do.I thought all I would have to do is slide the axel in place and tighten the 5 bolts and be done with it.
Re: 8 3/4 a body green bearings [Re: Dons Dart] #613071
02/14/10 09:12 PM
02/14/10 09:12 PM
the snap ring is on the outside of the green bearing along with a o-ring
the flage goes on the axle then the bearing then the lock coller
the bearing slides into the ends of the housing,the o-ring seal in the end cub and goes in till the snap ring is against the flange
now the bear retaining flange bolts to the 5 studs and pinches the snap rear to hold the bearing in place
no endplay adjustment needed
kinda simple once you see the bearing and retaining flange
the roller ball bearings do not like the extrem side loading
Re: 8 3/4 a body green bearings [Re: Dons Dart] #613072
02/14/10 09:14 PM
02/14/10 09:14 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
..i know no adjustment is required but thought maybe there was something else.
Re: 8 3/4 a body green bearings [Re: can.al] #613073
02/14/10 09:46 PM
02/14/10 09:46 PM
Canada
Canada
Ok i need a pic of that would like to see what I could be in for lol.
Re: 8 3/4 a body green bearings [Re: Dons Dart] #613074
02/14/10 10:13 PM
02/14/10 10:13 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
It’s so funny; many of these types of things never come with instructions. Yet after the first time you do it you wonder why they would?
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: 8 3/4 a body green bearings [Re: HealthServices] #613075
02/14/10 10:17 PM
02/14/10 10:17 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Good picture, except the inner (orange) seal is facing backwards.
Re: 8 3/4 a body green bearings [Re: DoctorDiff] #613076
02/14/10 10:20 PM
02/14/10 10:20 PM
So Cal
So Cal
you are right, you are keeping the oil in the axle And Cass will get you about the best pricing too.
Re: 8 3/4 a body green bearings [Re: HealthServices] #613077
02/14/10 10:25 PM
02/14/10 10:25 PM
Canada
Canada
He has given me a price looks good.witch one is the snap ring.hey Doctor Diff does yours come with instructions R&R.Looks simple.
Re: 8 3/4 a body green bearings [Re: Dons Dart] #613078
02/14/10 10:28 PM
02/14/10 10:28 PM
So Cal
So Cal
If that is what they call it.
