Wide MP W2/W5/W7/W9 Cover on an LA motor? #613015
02/14/10 02:15 AM
02/14/10 02:15 AM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
Just curious if it's possible to use the wide MP aluminum valve covers P4876124 on an LA motor. Anybody out there done it? Any pros or cons?
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: Wide MP W2/W5/W7/W9 Cover on an LA motor? [Re: MadMatt] #613016
02/14/10 02:01 PM
02/14/10 02:01 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
One more try...
Re: Wide MP W2/W5/W7/W9 Cover on an LA motor? [Re: MadMatt] #613017
02/14/10 02:10 PM
02/14/10 02:10 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
..my mopar performance catalogue says yes.
Re: Wide MP W2/W5/W7/W9 Cover on an LA motor? [Re: MadMatt] #613018
02/14/10 03:42 PM
02/14/10 03:42 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
This guy is running them on Eddie heads. Just a picture I saw on another site. Not my motor.
Re: Wide MP W2/W5/W7/W9 Cover on an LA motor? [Re: autoxcuda] #613019
02/14/10 04:09 PM
02/14/10 04:09 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Re: Wide MP W2/W5/W7/W9 Cover on an LA motor? [Re: autoxcuda] #613020
02/14/10 05:10 PM
02/14/10 05:10 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Pretty tight at the intake runners; my "regular" ones needed some modification to fit the runners on my Holley Strip Dominator intake. They're also so close to my (W2) pushrods that the gasket rails had to be narrowed at those locations, which might not be an issue with the wide ones.
