76 duster floors? #612687
02/13/10 08:53 PM
02/13/10 08:53 PM
NC
Tommy383 Offline OP
Tommy383  Offline OP
NC
will the 73 pans work...asked an AMD dealer, and they didnt know...hope they do...i need some new pans
Re: 76 duster floors? [Re: Tommy383] #612688
02/13/10 08:57 PM
02/13/10 08:57 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Would the drivers side be different on the 76 due to the cat converter?
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: 76 duster floors? [Re: 69L78Nova] #612689
02/13/10 09:04 PM
02/13/10 09:04 PM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
The drivers side is different, I have a 76 dart sport. Changed bench to buckets and had to make sure to get the 76 brackets as earlier would not work due to raised floor for cat.
Rob Dunn
1976 Dart Sport 360
2000 dakota RT 408 with 150 nitrous
2013 Dodge Ram 1500 Hemi
2009 Jeep Patriot
Re: 76 duster floors? [Re: blk00rt] #612690
02/13/10 09:11 PM
02/13/10 09:11 PM
NC
Tommy383 Offline OP
Tommy383  Offline OP
NC
if i plan on putting my own seats in with different brackets....will the floors weld in or will there need to be fab work done?
thasnks
Re: 76 duster floors? [Re: Tommy383] #612691
02/13/10 10:06 PM
02/13/10 10:06 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
Both floor pans are pretty much the same on the perimeter edge so yes it will weld in...BUT your 76 has a raised hump in the floor pan under the driver side seat to accomodate the catylitic converter. 73's had no cats so no hump either. If your required to run the cat on your car you can not use the earlier floor pan.
Re: 76 duster floors? [Re: nomore65BelvJim] #612692
02/13/10 11:23 PM
02/13/10 11:23 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
As long as you aren't installing a cat, the earlier pans will work.
Send me a PM if you are interested in a factory pan from a 74 duster
