Re: What motor oil to use?
[Re: moparcanuk]
#61244
05/21/08 10:48 PM
05/21/08 10:48 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
The current engine oils today are,for the most part all high quality products.Use whatever you feel comfortable with.
[Re: moparcanuk]
#61250
05/22/08 03:06 PM
05/22/08 03:06 PM
Try doing a search for "Amsoil". Some of their oils are made for older cars with lots of zinc and phos. Also, the oils are group 4 PAOs, top notch. BTW, that is one sweet GTX!
#61251
05/22/08 06:37 PM
05/22/08 06:37 PM
Posts: 6,516 Santa Cruz, California
Lefty
If you can afford buying a lot of oil at one time and save for future use, Lubrication Engineers oil is hard to beat performance wise. I buy multiple products (ATF, diesel oil, diesel fuel additive, gasoline additve, etc...) to make up the minimum order. This is what I use in my Cummins Ram and 440ci Coronet motor - http://www.le-inc.com/products.jsp?productID=38
