first time in real down draft booth any hints? #610981
02/11/10 10:10 PM
02/11/10 10:10 PM
Columbus Ga
reflections7 Offline OP
Columbus Ga
Ive painted for 20 years but never in a real heated downdraft booth. Im excited. painting a 67 belevedere sat in a heated downdraft professional booth. car is ready. 2008 dodge pearl red. lots of work but I think it will be real nice. will the paint dry faster between coats because the extra airflow? I plan on using med reducer. should be ok. Im used to waiting between coats because my airflow isnt or hasent been real good in my garage paint jobs. http://img.photobucket.com/albums/v313/reflections7/100_0082.jpg
http://img.photobucket.com/albums/v313/reflections7/0210001559a.jpg
http://img.photobucket.com/albums/v313/reflections7/100_0075.jpg
http://img.photobucket.com/albums/v313/reflections7/DSC01888.jpg
http://img.photobucket.com/albums/v313/reflections7/1008091305.jpg
http://img.photobucket.com/albums/v313/reflections7/CopyofDSC01896.jpg
Re: first time in real down draft booth any hints? [Re: reflections7] #610982
02/11/10 10:46 PM
02/11/10 10:46 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
use reducer based on room temp. Our booths are set at 85 degrees during painting. We use slow reducers. Flash time between coats for color is about 5 mins. Clear is about 10 to 15 mins. Car is dust free in 45 mins. Pick the temp reducer based on what the room temp will be during spraying.
Re: first time in real down draft booth any hints? [Re: Dougsmopars] #610983
02/11/10 11:07 PM
02/11/10 11:07 PM
fury4speed Offline
fury4speed  Offline
A Few things , were old shoes because they will be full of overspray when you are done spraying your car , and I assume you are going to wear a "Spray Suit" that helps a bunch with dirt , be aware where the 'Air Hose" is at all times , do not step on the hose while it is on the exhaust grate as you will loose Air Pressure at the Gun for a split second and paint will dribble on your car. I assume you are shooting "Solventborne" paint?
Re: first time in real down draft booth any hints? [Re: fury4speed] #610984
02/11/10 11:38 PM
02/11/10 11:38 PM
Columbus Ga
Columbus Ga
Been painting for 20 years just never in a booth like this. Best i ever used was old cross draft booth. real old. This is new high tech down draft heated booth. Very well lit which will be nice. I wear all my ppp personal protection equipment. mask, suit, hood, ect. Just dont think I will be used to how fast it flashes.
Re: first time in real down draft booth any hints? [Re: reflections7] #610985
02/12/10 12:15 AM
02/12/10 12:15 AM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
Yes paint dries fast! A second person is a must.
Snap your neck, mega G-force launch, is all I want!
Re: first time in real down draft booth any hints? [Re: reflections7] #610986
02/12/10 12:31 AM
02/12/10 12:31 AM
Jacksonville Florida
elitecustombody Offline
just use slow reducer with base and slowest hardener with clear
