Steering Gear mounting bolt torque spec? #61059
05/21/08 04:18 PM
05/21/08 04:18 PM
Slantytown
DUFFMAN Offline OP
Ask And Ye Shall Receive
DUFFMAN  Offline OP
Slantytown
Can anybody tell me what the steering gear mounting bolts on a 1972 B-body with manual steering gear should be torqued to?
I checked the tech archieve here and I have the factory service manual but I couldn't find it in either place.
No longer taking $h!t from anyone!
Re: Steering Gear mounting bolt torque spec? [Re: DUFFMAN] #61060
05/21/08 06:05 PM
05/21/08 06:05 PM
Washington Twp., Southern NJ
Fastfrankie Offline
Fastfrankie  Offline
As tight as you can get them by hand...run them up with an impact if you like!
Re: Steering Gear mounting bolt torque spec? [Re: Fastfrankie] #61061
05/21/08 07:08 PM
05/21/08 07:08 PM
Eastern Ohio
mopowergtx Offline
mopowergtx  Offline
Eastern Ohio
1976 Chrysler manual sitting heres says
Manual Steering
Gear assembly to frame bolt 100 ft lbs
Re: Steering Gear mounting bolt torque spec? [Re: mopowergtx] #61062
05/21/08 07:44 PM
05/21/08 07:44 PM
Fastfrankie Offline
Fastfrankie  Offline
No need to break out a torque wrench for those bolts. You'd be the laughing stock of the shop if fellow wrench's saw you using a torque wrench on a steering box bolt!
100ft pounds is about the equivalent to as tight as you can get it with a socket and 1/2 ratchet!
Re: Steering Gear mounting bolt torque spec? [Re: Fastfrankie] #61063
05/22/08 08:53 AM
05/22/08 08:53 AM
Slantytown
DUFFMAN Offline OP
DUFFMAN  Offline OP
Slantytown
The thing is I have a clunking noise coming from the front end during acceleration and braking so I want to make sure that everything is torqued sufficiently.
My 1968 service manual says 80 ft.lb so that's what I torqued it to. If the noise is still there I guess the next step is to take the brakes apart and make sure the adjusters are working.
Re: Steering Gear mounting bolt torque spec? [Re: DUFFMAN] #61064
05/22/08 10:02 AM
05/22/08 10:02 AM
give everything the once over. inner/outter tierods, upper/lower balljoints, strut rod bushings, etc.
Re: Steering Gear mounting bolt torque spec? #61065
05/22/08 01:41 PM
05/22/08 01:41 PM
Slantytown
DUFFMAN Offline OP
DUFFMAN  Offline OP
Slantytown
Yep, that's the idea. I've gone through just about everything and it all seems tight, do if it still exsists the next thing to look at is the brakes.
Re: Steering Gear mounting bolt torque spec? [Re: DUFFMAN] #61066
05/23/08 09:05 AM
05/23/08 09:05 AM
Hunt Valley, Maryland
1fastrunner Offline
1fastrunner  Offline
Have you considered the steering coupler? I chased my noise and vibrations to it. Now, I have to figure out how to fix it using the $10 rebuild kit.
Re: Steering Gear mounting bolt torque spec? [Re: 1fastrunner] #61067
05/23/08 09:12 AM
05/23/08 09:12 AM
Slantytown
DUFFMAN Offline OP
DUFFMAN  Offline OP
Slantytown
The coupler is fine. The car only has 58K original miles on it.
I had the car up in the air Wednesday so while I was under there I checked the torque on all the bolts/nuts holding the suspension together including the sterring gear shich I torqued to 80 ft.lb per my 1968 service manual. Also while i was under there I greased the ball joints and tie rod ends. I did something right becuase the cluck seems to have gone away.
