Rear Axle Side Rail Bumpers - Where can I get them? #61050
05/21/08 03:33 PM
05/21/08 03:33 PM
Arizona
68CoronetRT Offline OP
Arizona
My manual shows a bumper #2834-934 called a rear side rail bumper but I cannot find them listed anywhere. It mounts in the arched area of the frame rail above the rear axle and looks like a piece of rubber with metal mounting straps on each side.
Re: Rear Axle Side Rail Bumpers - Where can I get them? [Re: 68CoronetRT] #61051
05/21/08 03:54 PM
05/21/08 03:54 PM
r/t specialties has them,tom is a great guy.
Re: Rear Axle Side Rail Bumpers - Where can I get them? #61052
05/21/08 04:03 PM
05/21/08 04:03 PM
Arizona
Arizona
Thanks.
Re: Rear Axle Side Rail Bumpers - Where can I get them? #61053
05/21/08 04:32 PM
05/21/08 04:32 PM
rochester michigan, oakland co...
drmonday Offline
drmonday  Offline
I completely agree, Tom is the only guy to buy from. Great products! Great Service!
Re: Rear Axle Side Rail Bumpers - Where can I get them? [Re: 68CoronetRT] #61054
05/21/08 10:24 PM
05/21/08 10:24 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
If you have the original ones that are triangulated rubber with the metal strap, it can be replated. Insert a screwdriver between the rubber and the metal, spray some lube in there and also do it to the other side. Once both sides are lubed, the strap can be slid out. You may have to clamp it in a vise for leverage, just wrap a rag around the metal to protect it.
The rubber can be cleaned with Acetone, Laquer Thinner, or Enamel Reducer.
