Do all 360 's have crank drilled? #60870
05/21/08 10:15 AM
05/21/08 10:15 AM
Ohio
B5TA Offline OP
B5TA  Offline OP
Ohio
Question I have a real good stock 360 out of a 1978 W150 truck that I bought new. Would it be drilled for pilot bearing?, if so what would be the best "manual" tranny to put behind it for AUTO use (not truck). School me please ! Kev
Re: Do all 360 's have crank drilled? [Re: B5TA] #60871
05/21/08 10:23 AM
05/21/08 10:23 AM
places
79powerwagon Offline
places
"Yes!
I mean NO!
I mean...
HUH?"
(Patty Donahue of the Waitresses, song "Square Pegs)
Sorry man, I couldn't resist!
Re: Do all 360 's have crank drilled? [Re: 79powerwagon] #60872
05/21/08 10:35 AM
05/21/08 10:35 AM
Ohio
B5TA Offline OP
B5TA  Offline OP
Ohio
Ok I'll try again! Have a 360 out of a W150(1978)with an automatic transmission. My question is since it was an auto. trans would the pilot bearing hole be drilled in the end of the crank? If it is, what would I look for to put a manual transmission behind it. I have a Brand X car that may get an engine swap and I thought I may go with a manual if I could get the stuff I need. Thanks!
Re: Do all 360 's have crank drilled? [Re: B5TA] #60873
05/21/08 12:43 PM
05/21/08 12:43 PM
dogdays Offline
dogdays  Offline
Use the pilot bearing that fits in the torque converter ring and trim the excessive length off your input shaft. That way you don't have to try drilling a hole in a crank.
R.
Re: Do all 360 's have crank drilled? [Re: B5TA] #60874
05/21/08 08:39 PM
05/21/08 08:39 PM
Ohio
B5TA Offline OP
B5TA  Offline OP
Ohio
for the night shift people!
Re: Do all 360 's have crank drilled? [Re: B5TA] #60875
05/22/08 01:45 AM
05/22/08 01:45 AM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
I don't know the number for the bearing, but the bushing for the TC register is an SKF B287. Costs me about 3 bucks a piece the last time I got one.
I'd go this route and circumcise the input too...
2 Demons...no, not my kids!
Re: Do all 360 's have crank drilled? [Re: 4speeds4me] #60876
05/22/08 07:36 AM
05/22/08 07:36 AM
Stoney Creek, Ontario, Canada
76Beeper Offline
76Beeper  Offline
Go down to your local dealship & order 53009180 which is the needle bearing.
It fits into the converter pilot hole & job done.
No need to worry if the crank if finish drilled.
