shifter box id? #60834
05/21/08 08:55 AM
05/21/08 08:55 AM
central new york
pettyblue440 Offline OP
central new york
Could someone id this for me? it is attached to a 70 b body console pistol grip and I am wondering if it is correct for the application. thanks
Hurst Competition Plus Patent# 3210274
1090444K , 6356
Re: shifter box id? [Re: pettyblue440] #60835
05/21/08 11:45 AM
05/21/08 11:45 AM
Ky
jt4406 Offline
jt4406  Offline
Ky
Check for numbers stamped into the reverse lever (longest one):
"These numbers are found stamped into the Reverse lever:
2336= '64-'65 A & B Body
6353= '68-'69 B Body and '68-up A body
7174= '70 only B Body
7180= '70-'74 E Body and '71-up B Body "
Quoted from Moparts member John K.
jt
Yeah, it's hopped up to over 160...
Re: shifter box id? [Re: jt4406] #60836
05/21/08 01:36 PM
05/21/08 01:36 PM
michigan
70 buzz Offline
70 buzz  Offline
michigan
My shifter is marked 7172 [70SB]
