Re: REAR MAIN CHANGED- STILL LEAKING
[Re: Dennispsalm91]
#60777
05/21/08 09:20 AM
05/21/08 09:20 AM
Posts: 1,136 Byesville, Ohio
Tomsecks
Byesville, Ohio
What's the story on the engine? Rebuild? I fought a rear main on mine for about 2 years after I rebuilt it, small block. 3 seperate times I took my trans out, once I siliconed the cam plug, once I changed the rear main in the car, no improvement. Finally I yanked the engine, and changed to a rope seal.
Here's what my problem was, the crank was wore where the seal was suppose to seal. I happened to have a brand new crank to measure, sure enough mine was about .010" too small, so it wouldn't seal. I tossed the rope seal in it, no problems since.
[Re: Dennispsalm91]
#60780
05/21/08 07:26 PM
05/21/08 07:26 PM
I just changed mine turn out it was in backwards, no more leaks.
[Re: 68CoronetRT]
#60783
05/21/08 08:12 PM
05/21/08 08:12 PM
Posts: 651 Florida
Dennispsalm91
the crank looks ok, but i didnt mic it, maybe the rope seal will work, its just very frustrating, the plug was concave , but i dont for sure know if thats were the leak is, until i pull the trans.
