Re: Chrome Box [Re: ZIPPY] #60542
05/22/08 11:39 AM
05/22/08 11:39 AM
Oh
RacerGofKGB Offline
Got The Big One
RacerGofKGB  Offline
Got The Big One
Oh
O/T Does anyone have a part number for the .25 or .75 ohm resistor? Summit has two different two prong resistors, but they dont tell you the difference between the two.
Re: Chrome Box [Re: MadMax58] #60543
05/22/08 04:50 PM
05/22/08 04:50 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
I have been running a chrome box with the 1.00 ohms ballast resistor for over 10 years on the street. What difference would I notice if I changed the 1.00 ohms ballast resistor to the the 0.25 ohms ballast resistor?
Many people confuse the issue..
A lower resistance ballast resistor, will run the coil @ a higher voltage.. We have been running the Mopar Blaster coil along with the 0.25 Ohms resistor for quite a while. And often someone will say that the 0.25 Ohms ballast is the wrong one as it should be of higher resistance. We keep a copy of the tech sheet suppled with the blaster coil in the glove box and in these instances people just shake their head and move on.
Just my $0.02..
Re: Chrome Box [Re: RacerGofKGB] #60544
05/22/08 04:54 PM
05/22/08 04:54 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
The Mopar part # for the 0.25 Ohm version is
2444 641...
Re: Chrome Box [Re: Sinitro] #60545
05/22/08 07:48 PM
05/22/08 07:48 PM
Oh
RacerGofKGB Offline
Got The Big One
RacerGofKGB  Offline
Got The Big One
Oh
Thanks for the p#
Re: Chrome Box [Re: ZIPPY] #60546
05/22/08 10:00 PM
05/22/08 10:00 PM
ontario canada kingston
aspenrt360 Offline
aspenrt360  Offline
They are made by the lowest bidder China.
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
Re: Chrome Box [Re: aspenrt360] #60547
05/22/08 11:22 PM
05/22/08 11:22 PM
northeast ohio
mkdart Offline
mkdart  Offline
northeast ohio
The chrome box in my car is about 25 years old.
Just bought an orange box to keep in the trunk,
Mancini is selling knockoffs for 10 bucks. Mike
Re: Chrome Box [Re: mkdart] #60548
05/23/08 08:06 AM
05/23/08 08:06 AM
South Georgia
tx9cuda Offline
tx9cuda  Offline
South Georgia
This has gotten a little confusing-Which resistor should be run with the chrome box and production coil ??
1971 BS23H1B
Re: Chrome Box [Re: tx9cuda] #60549
05/23/08 10:49 AM
05/23/08 10:49 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
For a chrome box+stock coil, or even a performance coil that you want to run for a LONG time), a 1 ohm resistor works very well. Spark quality won't be quite as nice as with a 1/4 ohm resistor, but the parts should live a very long life.
