paint code???? #60318
05/20/08 01:48 PM
05/20/08 01:48 PM
western Ky
CraigS Offline OP
CraigS  Offline OP
western Ky
Hey,
Any one out there that can decode a paint code?
It is a 67 coronet with the code 881.
this is the code on the data plate under the "PNT"
I have found several websites that do this ,and I found a code for ppg as 13336.When i take this in to get paint ,they say it is a gm code,not dodge.
I want to get this color right,but need more info
anyone?
Thanks in advance......craig
Re: paint code???? [Re: CraigS] #60319
05/20/08 03:10 PM
05/20/08 03:10 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
check www.autocolorlibrary.com you should find the paint code you need just select domestic,dodge and 1967.
Re: paint code???? [Re: CraigS] #60320
05/20/08 03:16 PM
05/20/08 03:16 PM
Farmington, CT
KISSAlien Offline
KISSAlien  Offline
Farmington, CT
Technically the paint code is 88. The 1 just refers to the fact that the whole car is painted the same color instead of it being 2-tone. 13336 is the correct Ditzler code for that paint color.
