Max Wedge Intake with Aftermarket A/C Question #60226
05/20/08 12:02 PM
05/20/08 12:02 PM
Perry, OK
tkulak Offline OP
tkulak  Offline OP
Perry, OK
Has anyone seen a Sanden style compressor run with a Max Wedge setup? If so if you have any pics, they would be much appreciated. This car has a Hot Rod Air aftermarket air setup with an A and A Max Wedge style intake. Or is it possible to run the stock style compressor? Need help on the A/C bracket, setup.
Re: Max Wedge Intake with Aftermarket A/C Question [Re: tkulak] #60227
05/20/08 12:59 PM
05/20/08 12:59 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
This one should work with any intake.
http://bouchillonperformance.com/BPE4705.asp
Rich H.
Esse Quam Videri
Re: Max Wedge Intake with Aftermarket A/C Question [Re: ZIPPY] #60228
05/20/08 01:26 PM
05/20/08 01:26 PM
Perry, OK
tkulak Offline OP
tkulak  Offline OP
Perry, OK
Thanks, I am going to go with this one. Same company.
