Page 3 of 3 1 2 3
Re: 500" Engine Build 440 Source? [Re: Von] #602170
02/10/10 12:36 PM
02/10/10 12:36 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
so 915 with .040 quench what compression can I run and still use pump regular or premium?
About 9.5:1 with the steel heads.
Dave [/quote)
I dang sure dont agree with this statement. Im running 10.5 with open chamber iron heads, without any detonation problems. No quench whatsoever. Of course I have a decent sized cam, [Email]259@.050[/Email], but 9.5 is on the conservative side.
I agree with Von because as I said I am running 10.0 with 906 heads and no ping at all. I even run on 92 pump alot as thats all some of my local stations have. I do have fairly good quench as all cylinders are in the .040 to .042 area and I use the MP .557 cam. Ron
Re: 500" Engine Build 440 Source? [Re: Von] #602171
03/01/10 09:12 AM
03/01/10 09:12 AM
Detroit, MI
kz5rt2 Offline OP
kz5rt2  Offline OP
Detroit, MI
Just a quick question. I had overheating problems on a prior engine that was bored out 0.060. I have two possible engines I can use, one is an early 440 that cleans up at 0.040 and the other is a late 440 with stock bore that would be 0.030.
I'm partial to using the early 440 at 0.040 bore, would this extra bore factor into any scenarios of overheating?
Re: 500" Engine Build 440 Source? [Re: kz5rt2] #602172
03/01/10 12:25 PM
03/01/10 12:25 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I would use the late 440. The later 440's gained a small amount of strength over the earlier ones and you can sell the earlier one to someone who cares about date codes.
Re: 500" Engine Build 440 Source? [Re: DaytonaTurbo] #602173
03/01/10 12:54 PM
03/01/10 12:54 PM
Corpus Christi, TX
shanker Offline
shanker  Offline
Corpus Christi, TX
It took me 4 years to find a standard bore 1978 440 casting...the only difference is a little more meat casted into the bottom of the block though.
The Federal Government has not yet learned that you cannot legislate morality 1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23 1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55 1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91 1975 Duster 360 VS29L5 Daily Driver
Page 3 of 3 1 2 3
