Good Denver machine shop?
#601967
02/02/10 07:27 PM
02/02/10 07:27 PM
Posts: 319 Denver
Explodo
Denver
How would you go about finding a good machine shop for block work? I'd love to find one that knows all about the work required for a 440 block to really sing, but I have no idea how to sort the really good shops from the ones that just say that they're really good.
'67 440 Satellite
Re: Good Denver machine shop?
[Re: Explodo]
#601968
02/02/10 07:44 PM
02/02/10 07:44 PM
RapidRobert
word of mouth is the best way. Hopefully someone on here is in the Denver area and can recommend someone who is a perfectonist. If not a local car club or even a parts store employee might be helpful/have a good person/shop to recommend.
[Re: RapidRobert]
#601969
02/02/10 07:46 PM
02/02/10 07:46 PM
Posts: 319 Denver
Explodo
Denver
I guess that's pretty much what I'm hoping for...someone who actually knows a good shop in the area for doing Mopar work.
'67 440 Satellite
[Re: Explodo]
#601971
02/02/10 11:25 PM
02/02/10 11:25 PM
Posts: 1,822 Colorado
denfireguy
Colorado
I know several people who have had good luck with Ridge Reamers. Also Western Engine Supply has a decent reputation but I am not sure about their experience with Mopar. I have checked out Havana Auto Parts. Prices are pretty high but they seem to be well equipped. Let us know how you do. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: Explodo]
#601972
02/03/10 12:17 AM
02/03/10 12:17 AM
Posts: 319 Denver
Explodo
Denver
Thank you both very much for the recommendation.
'67 440 Satellite
[Re: Explodo]
#601974
02/03/10 04:51 AM
02/03/10 04:51 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I have only used three machine shops in the Denver area: The Block Shop, They are on 2373 South Plate, near SanteFe and Evens. MadCap racing engines, 7895 W14th, Lakewood American Automotive Machine, Don Hackenberg, 8672 Emmerson Ct, Denver.
I have not used Ridge Reamers?
All those listed above have torque plates for Mopars. MadCap has the lifter bore fixturing, if you need the lifter bores corrected and bushings installed. They are usually really busy with race engines, so it may take several weeks to get your engine machined there. The Block shop does nice work and they usually will have a block machined in about a week or less. They can align hone the mains, but they do not align bore / fit aftermarket main bearing caps. Don Hackenberg at AAM specializes in Mopar engines. He has built alot of Mopar race engines. He runs a small shop, so he may be busy? Don got me a good price on fitting my BCR aluminum main caps and girdle.
[Re: zgardulski]
#601977
04/24/10 02:17 PM
04/24/10 02:17 PM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
Another for Ridge Reamer. The did all the work for my 340 and have done several other projects. They are not the cheapest guys in town but when you get it back it will be done right. They did some work on a couple Onan 2 cylinder motors for me and it came out great! Gunn Automotive isn't bad for a cheaper alternative either. They did the work for my dad's 350 and it was nice work at a great price. They have been around for 20+ years as well.
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
[Re: 53HenryJ]
#601979
09/29/11 03:51 AM
09/29/11 03:51 AM
quick77rt
Parts Problem
Parts Problem
I know this is an older post, but I had to start the task of finding a machine shop here in Denver and of several I called, only Ridge Reamer knew right off what I meant when I said X block...most shops ask why does this 318 has a X on it.
Second, the fist two shops I mentioned tq plates...nope...Asked RR and it was of course.
Walked in the door and seen a wall full of mostly mopars from the past, about 40 cranks ready to go out the door and a set of hemi heads and some other hi po stuff.
I questioned my math on deck height and they simply said bring the crank,rod,ect...took them 5 minutes and it was decided. We both got the same numbers.
Priced right, very helpful, very comfortable feeling overall from the start...I dont think I will be sending my blocks to atlanta anymore.
Talked about some different things...Im sold.
From above...
Downside is that you have to preplan your build as he is very busy. Call now for a build start time.
I did, more or less made an appointment, 4 days for a simple .080 bore/hone, may of been 3 if I hadnt had to go bck witht he crank, ect...
Currently it seems they are about two weeks out and they are not complaining about that......
Anyone see the muastang shop ringt near him....I seen some nice cars...esp a black and red mach 1 possibly.
