727 torque converter question #60068
05/20/08 08:45 AM
05/20/08 08:45 AM
own private Idaho
N
ngpSatellite Offline OP
N
own private Idaho
My car stalls out in gear and I'm wondering if the torque converter is bad or not installed properly... the mopar book states that the when the TC is installed you'll have 3 distinct engagements...is it possible to hook the trannie up with the TC not engaged fully(2 engagements) I have no leaks and the motor runs in nuetral and park but when I put it in gear ir stalls evrything seemed to have lined up properly to the flex plate when I installed it
Re: 727 torque converter question [Re: ngpSatellite] #60069
05/20/08 08:51 AM
05/20/08 08:51 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
No it won't work. Personally I have never felt the 3 engagements but only 2 definite ones.
If it is not installed fully engaged you will damage the transmission pump.
Re: 727 torque converter question [Re: MoparforLife] #60070
05/20/08 09:10 AM
05/20/08 09:10 AM
own private Idaho
N
N
own private Idaho
OK ..I know I felt 2 definite engagements as well..thats why I was asking..I don't remember the third one but I know it was seated all the way in. the stock flex plate fit perfectly when I mated the trannie to the engine. the engine and trannie are in the car..can I disconnect the flex plate and try to push the TC in more?
Re: 727 torque converter question [Re: ngpSatellite] #60071
05/20/08 09:12 AM
05/20/08 09:12 AM
Upper Midwest
Upper Midwest
If your converter spun freely and you had to pull it forward slightly to mate up to the flexplate it is ok.
Re: 727 torque converter question [Re: MoparforLife] #60072
05/20/08 09:17 AM
05/20/08 09:17 AM
own private Idaho
N
N
own private Idaho
Thanks for the advise!! thats exactly how it hooked up so you saved me alot of troubleshooting work!
Re: 727 torque converter question [Re: ngpSatellite] #60073
05/20/08 09:55 AM
05/20/08 09:55 AM
scratchnfotraction Offline
does it have a big cam in it?
check timming and idle setting maybe
to big a cam and not enuff stall will kill it when ya drop in to gear
good luck
