NEED SOME DODGE NEON HELP........HELP HELP #59923
05/19/08 09:35 PM
05/19/08 09:35 PM
so cal,cali
calimoparguy Offline OP
so cal,cali
The light on my wifes neon came on and it started dieing the code P0106 came up,what does that mean...i looked up the code and it said
p0106-Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
but im not sure what the problem is,does it mean the map sensor is bad???
Re: NEED SOME DODGE NEON HELP........HELP HELP [Re: calimoparguy] #59924
05/19/08 09:36 PM
05/19/08 09:36 PM
yup
Re: NEED SOME DODGE NEON HELP........HELP HELP #59925
05/19/08 10:10 PM
05/19/08 10:10 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not necessarily.
What it means is that the computer isn't seeing what it exects to see.
It could be the MAP sensor, the wiring, the voltage to the sensor or the computer.
Don't be the exception.
Re: NEED SOME DODGE NEON HELP........HELP HELP [Re: Supercuda] #59926
05/19/08 10:22 PM
05/19/08 10:22 PM
true enuff. so i'll revise my answer to its 99.9% likely its the MAP sensor.
