Re: Ideal quench distance
[Re: mopowergtx]
#59912
05/19/08 09:34 PM
05/19/08 09:34 PM
yup .040". BUT with a open chamber head, you'll need a set of "reverse dome" or "quench style" pistons. KB seems to be the master of that.
[Re: mopowergtx]
#59913
05/19/08 09:57 PM
05/19/08 09:57 PM
RapidRobert
.035-.040" & the recessed area on open chamber heads varies in slope & needs to be machined flat to get it "right",that & KB pistons as mentioned which will also need the dome to be machined makes getting quench on an open chamber headed engine more $$$$ but an engine without proper quench isn't efficient & definitely more prone to ping & you're leaving power on the table. I'm .110 in the hole on mine(SB) & I am going to get it with .050 undersize rod bearings & some deck milling.
#59914
05/20/08 12:06 AM
05/20/08 12:06 AM
Would less be better as far as power ?
[Re: mopowergtx]
#59916
05/20/08 07:50 AM
05/20/08 07:50 AM
Posts: 74,974 U.S.S.A.
JohnRR
U.S.S.A.
Is the number you shoot for .040 with an open chamber iron head? What I got is a flat top piston and my farthest one down is .008 in the hole with a .028 head gasket an .011 on the flat of the head to the small flat area in the chamber of my small block J head. Oh and on the other side pistons are zero with the deck. I just had the shop clean the decks till they were flat is why the difference from on side to the next. The side that is zero now was high from one end to the other and accounts for why a little more was taken of the deck on that side. It was pretty flat just not true with the crank front to back when it left Mopar orignally back in 1967.
am i reading this correctly ??? one bank of pistons is .008 in the hole and the other side is at zero ???
how are you measuring it ? with feeler blades or a deck bridge and a dial indicator ?
[Re: 451Mopar]
#59917
05/20/08 10:24 AM
05/20/08 10:24 AM
Posts: 1,047 Arizona
68CoronetRT
Arizona
. . . Ideal quench distance is as close to zero when the engine is running at max RPM without the piston hitting the head. . .
The danger in trying to get too close is the tolerance factor. Every part i.e. crank, rods, pistons, valves, etc. all have some degree of variation in their movement. If each of the parts named above has say +/- .001 tolerance there is a cumulative +/- .004 amount of movement potential. There is also the expansion due to heat and the stress of high rpms that can introduce even more movement. Hence, the .035-.040 quench range gives you the desired affect of reducing detonation as well as improving power while not endangering your engine. As stated earlier the easiest way to achieve this is with flat top pistons at zero deck and after market closed chamber heads using a .039" head gasket.
[Re: dmerc]
#59922
05/20/08 01:55 PM
05/20/08 01:55 PM
Posts: 3,075 Eastern Ohio
mopowergtx
Eastern Ohio
I'm running .031 quench on my tallest piston. This on a 408 stroker that doesn't rev past 5000 rpm. They all vary a few thousanths but I have seen no evidence that there is any problem.
I plan to spin this one to 6500 so I kinda wanted to make sure I wasnt getting to close to the head.
