Power brake booster question #59886
05/19/08 08:42 PM
05/19/08 08:42 PM
Cochise County Arizona
SPWC Offline OP
SPWC  Offline OP
Every week I make it a ritual to check the fluids in my wagon. Every week I end up adding brakefluid because the master is almost empty.
Someone advised me to try puttin a stick down into the power booster hole where the vacuum hose goes to see if theres brake fluid in my booster.
Did that today and discovered brake fluid down inside my booster...What does this indicate?
Obviously a problem with my master cylinder leaking..but can anyone identify the problem specifically?
Re: Power brake booster question [Re: SPWC] #59887
05/19/08 08:47 PM
05/19/08 08:47 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
primary piston, secondary cup seal...i think, would be leaking. You need a new master, you'll likely need a new booster too because the brake fluid will tear up the rubber.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Power brake booster question [Re: SPWC] #59888
05/19/08 10:56 PM
05/19/08 10:56 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
It's time for a new/rebuilt master cylinder and booster.
