Idle mixture screw has no effect! #59881
05/19/08 08:39 PM
05/19/08 08:39 PM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
Had a problem with my idle mixture screws a few days back. While working on it today to get the best idle, I have discovered that the drivers side idle mixture screw has little or no effect. The passenger side works fine. I'm thinking some kind of dirt or debrie in the driver's side circuit. Any other opinions?
Thanks!
Re: Idle mixture screw has no effect! [Re: polkat] #59882
05/19/08 08:48 PM
05/19/08 08:48 PM
Kirkland, Washington
Pacnorthcuda Offline
If single plane manifold the entire engine may be idling on the one idle circuit (passenger in your example). YOu may also be able to richen the drive side and then crank down the passenger side and have the same effect.
You could have a blown power valve. You could have a clogged air bleed.
Is it idling rich???
Re: Idle mixture screw has no effect! [Re: Pacnorthcuda] #59883
05/19/08 09:00 PM
05/19/08 09:00 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Both screws should be turned out the same amount. Start with the screws about 1-1/2 turns out. Turn them in or out 1/8 turn at a time. If you can turn them both in all the way, then either you have a clogged air bleed, air bleed is too small, or the idle feed restrictor is too big.
Re: Idle mixture screw has no effect! [Re: polkat] #59884
05/19/08 09:25 PM
05/19/08 09:25 PM
no opinion here until you say what kinda carb you have, and any other relevant info.
Re: Idle mixture screw has no effect! [Re: polkat] #59885
05/19/08 09:28 PM
05/19/08 09:28 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
Thanks!
My holley had too much of the transfer slots exposed so the idle did nothing. I have a single plane manifold with a high lift cam designed to only pull 10 InHg at idle. Do a search for tuning carbs and you will find a ton of info on here.
