Vacuum schematic #59866
05/19/08 07:52 PM
05/19/08 07:52 PM
Batavia,Ohio,
Moparmick Offline OP
Batavia,Ohio,
I need a vacuum schematic for a 71 charger w/383 Auto can't find one anywhere Help! Mick
Re: Vacuum schematic [Re: Moparmick] #59867
05/20/08 08:35 AM
05/20/08 08:35 AM
COLLINGWOOD, ONT
71_deputy Offline
71_deputy  Offline
COLLINGWOOD, ONT
problem was there wasn't much in the way of vac on these cars.
main one was for the power brakes from the intake, then if you had cruise then it was taken off the extra bib off the power brake booster.
next was for air cond. car- off the tee of the intake.
next was for the distr. and that was off the carb.
then the pvc from the valve cover to the port on the carb.
so there wasn't a lot- I check the 71 manual and could't really find one!
