Master cylinder Mods #59817
05/19/08 06:56 PM
05/19/08 06:56 PM
alberta
Publicbottle Offline OP
alberta
So, I thought there was a residual pressure valve in the Master cylinder (rear resevoir) that needed to be removed to run rear disc brakes.....i took my new one from NAPA apart as well as my old original from my 69 dart and found nothing in either of them...
So my question is....what do i need to do to my master cylinder to run 4 wheel disc brakes??
Re: Master cylinder Mods [Re: Publicbottle] #59818
05/19/08 11:07 PM
05/19/08 11:07 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Nothing unless the brake balance is biased too much to the rear. 4 wheel disc setups don't need a hold off valve, proportioning valve, combination valve, etc... I doubt you will have any problem with the MC you're using.
