How would you rebuild this? #59792
05/19/08 04:44 PM
05/19/08 04:44 PM
Iowa
3
318Bruiser Offline OP
Iowa
Need suggestions on what parts to put in my Holley rebuild. What "cam", squirter and jets for this combo:
318
stock heads
small summit cam
600 cfm Holley
headers and dual exhaust
stock 904 and converter.
Re: How would you rebuild this? [Re: 318Bruiser] #59793
05/20/08 12:31 AM
05/20/08 12:31 AM
Iowa
3
Iowa
Re: How would you rebuild this? [Re: 318Bruiser] #59794
05/20/08 01:22 AM
05/20/08 01:22 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
318
stock heads
small summit cam
600 cfm Holley
I'd start with #62 jets, a 5.5 Power valve and about a stock sized shooter and cam, probbably a stiff vacuum secondary spring too.
Make sure all the passeges are clear in the metering blocks, and the accelerator pump check valve works correctly.
