will paint stick to gold cadnium plating? #597312
01/29/10 02:11 PM
01/29/10 02:11 PM
Texas
mprhound Offline OP
mprhound  Offline OP
Texas
what kind of prep work, this is for a 440source valley cover and engine paint, any thoughts?
Re: will paint stick to gold cadnium plating? [Re: mprhound] #597313
01/29/10 06:09 PM
01/29/10 06:09 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Its not chrome ... just prime and paint. If you're worried, muriatic acid will take the plating off - don't breath the fumes !!!
Re: will paint stick to gold cadnium plating? [Re: Stanton] #597314
01/29/10 07:27 PM
01/29/10 07:27 PM
IN
ahy Offline
ahy  Offline
IN
Yes - with a good degreasing and a coat of etching primer as insurance against peeling. Auto body stores, some auto parts stores and Eastwood carry the etching primer in spray bomb or liquid. Two part epoxy primer would work well also.
Re: will paint stick to gold cadnium plating? [Re: mprhound] #597315
01/29/10 08:27 PM
01/29/10 08:27 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Do you have a way to glass bead it? Glass beading is the best prep I have found for any of these kind of surfaces. Then clean and prime.
Master, again and still
Re: will paint stick to gold cadnium plating? [Re: mprhound] #597316
01/29/10 08:51 PM
01/29/10 08:51 PM
Jacksonville Florida
elitecustombody Offline
Etching primer will work just fine, blasting would help even more
Re: will paint stick to gold cadnium plating? [Re: elitecustombody] #597317
01/29/10 10:44 PM
01/29/10 10:44 PM
Texas
mprhound Offline OP
mprhound  Offline OP
Texas
yes, i have access to a blast cabnit to glass bead it, so that then etching primer is the concensus? sounds good to me, thanks all!
