Can you plug the Emissions Tubes on gas tank? #596367
01/28/10 11:51 AM
01/28/10 11:51 AM
Tucson, AZ
67G2THEX Offline OP
67G2THEX  Offline OP
Tucson, AZ
My 71 Chally has a 72 style tank, that has smaller tubing ID than the 71 original tank, therefore, when I fill up, it leaks. Can these 4 ports simply be plugged off with no ill effects?
Thanks.
1967 GTX 440 Auto Tribute
1968 Charger 440 Auto
1968 D100 318 Auto Stepside - Daily Driver
1974 Road Runner 318 Auto
1954 Coronet 2dr Hemi Std with O/D
73 Road Runner 360/4spd Sassy Grass - sold
71 Challenger R/T Clone 383 MAG Auto - sold
Re: Can you plug the Emissions Tubes on gas tank? [Re: 67G2THEX] #596368
01/28/10 12:03 PM
01/28/10 12:03 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
No I wouldn't.
Re: Can you plug the Emissions Tubes on gas tank? [Re: 67G2THEX] #596369
01/28/10 12:11 PM
01/28/10 12:11 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
The tank on my '72 was really dirty when I got it. I had a local radiator shop that I trust boil it out and seal it. I had doubts about all the emissions fittings so I plugged them and installed a vent line in the filler pipe. Works perfectly.
Re: Can you plug the Emissions Tubes on gas tank? [Re: 5spdcuda] #596370
01/28/10 12:18 PM
01/28/10 12:18 PM
Cincinnati, Ohio
Cincinnati, Ohio
Cool,
Those arn't emmissions vents, there the vents that insure the tank is vented in all postions when the car is parked and being driven. It's best to get the right tank for your vapor separator. They also insure the expansion tank inside your tank can funtion correctly.
Re: Can you plug the Emissions Tubes on gas tank? [Re: Challenger 1] #596371
01/28/10 12:59 PM
01/28/10 12:59 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
There is no expansion tank in any of the reproduction tanks.
Re: Can you plug the Emissions Tubes on gas tank? [Re: Snoopy] #596372
01/28/10 02:47 PM
01/28/10 02:47 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I don't think there was an expansion tank in the late 72-74 tanks anyway. The four tubes ran to the top four corners of the tank and that was it. The vapor separator was supposed to catch any fuel that came out of the tank durring filling.
You can't run a sealed gas cap and still use that tank. It has to be vented somehow. Use a vented cap or do what was mensioned above.
