found some TRW main and rod bearing, what do they fit?
#596108
01/27/10 10:13 PM
01/27/10 10:13 PM
Posts: 7,992 Escondido, CA. Ron Podsiadly,...
Mopar Ron
I was cleaning the garage today and found some bearings, can anyone tell me what they fit? mains- MS3277 P rods- CB526 P (2320cp) wrong # EDIT: CB527 not CB526 I am trying to find something on line thanks in advance, Ron....
Re: found some TRW main and rod bearing, what do they fit?
[Re: jvcuda]
#596112
01/28/10 04:08 PM
01/28/10 04:08 PM
Mopar Ron
The rod bearings cb527 are for big block mopars.the mains: are you sure of that number?
OK here is what I found on the boxes with the mains on the outer blue and white box is MS3277 P on the white inside box 5025 M std on the main thrust bearing 2333 raal std and on the other mains bearings 2332 rau std
seeing that these were all together and the rod bearings are for a 440, they are probably for a std 440
