Re: MP .557 solid cam help needed
[Re: 383man]
#596023
01/28/10 01:59 PM
01/28/10 01:59 PM
Posts: 4,041 michigan woods
imfixinmopars426
michigan woods
It is a huge undertaking to maintain a solid lifter cam.
Dead wrong.
As long as you have good adjusters you shouldnt need to adjust the valves very often.
Now if you have crap adjusters, that is another story. DAMHIK.
Von is dead right. As I stated I drive my 63 alot and race it 3 or 4 times a year and I only adjust my valves once a year. And they are usually not out of adjustment or only out a very little bit. I just use standard ductile iron rockers. Ron
if you get the understanding how they work,and adjust,you will never go back to a mudstick cam. get detailed instruction on how to adjust,and ck hot later,and GO!..and the FSM might help,but with that cam,make sure your on the "backside" of the lobes when making the adjustment...the big cam guys will explain in proper instructions .also did you have a good head guy go over the heads,or are they ready to run??? better ck .oh,just ck how many engines cam with solids..../6? sbc's by the thousands...ect ect..ya solids are scary,like the ones in my 1953 f-head jeep...
[Re: 440challenger]
#596024
01/28/10 02:47 PM
01/28/10 02:47 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
557 kicks azzzzz 11.30s in a full street car with power brakes
Power brakes here also using the MP .557 cam. Ron
[Re: dOc !]
#596027
01/28/10 09:35 PM
01/28/10 09:35 PM
Posts: 1,679 Mansfield,Ohio
moparrulzzz
Mansfield,Ohio
What is the current part# for the cam and or cam and lifters?
P4120661 according to Summit
[Re: 70VcodeCoronetRT]
#596031
01/29/10 01:18 PM
01/29/10 01:18 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
MP cams have always worked great were designed to make use of the Big mopar lifter way back in the day before anyone else thought of it. Cams designed for mopars not chevy's then cut on a mopar blank!!! But seems more today than ever degree should be checked with the tolerances of the cam dowel, cam gear dowel placement, crank gear keyway placement and so all can stack up to a cam way off and often retarded when the respond well to a little extra advance on a street or street strip motor. No cam works well degreed way off but mild cams are more forgiving?? But mild = slow in my book and who wants that???
#596032
01/29/10 02:11 PM
01/29/10 02:11 PM
Posts: 948 Alliance, Ohio
Valiant_Showoff
Alliance, Ohio
Well I might have to give the 528 a look again if there is no problems with the mp cams
I used to run the 528 before I stepped up the convertor a few years ago (and hence the switch to the 557) and was very, very happy with the 528 in my 360. It was a torque monster with great street manners.
My brother ran a 528 in his 440, 4-speed GTX on the street with very good results too.
I might be in the minority, but I love the old Mopar camshafts. The they be old school designs, but they were specifically designed for old school Mopar engines that we're still running today. Not a Chevy designed profile cut onto a Mopar shaft.
[Re: moparrulzzz]
#596034
01/30/10 03:43 AM
01/30/10 03:43 AM
Posts: 30,424 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
THX for the # ... I found it on the Jugs site ...along with the pricing.
What is up with some of that pricing ? .. the 590 cam is a bunch cheaper.
And keeping with the direction of this topic ... I would like to hear a "report card" on that 590 vs the 557 and 528.
[Re: Dodgem]
#596035
01/30/10 02:00 PM
01/30/10 02:00 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Hmmmm. That is an interesting statement. Although, Id bet my life the .200 numbers on a MP .557,.590 arent in the ballpark when compared to say a Ultradyne NF Lobe.
Anybody have the .200 numbers on a .557 or .590?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: MNobody]
#596036
01/30/10 02:07 PM
01/30/10 02:07 PM
Posts: 602 N.E.Ohio
pacifica
N.E.Ohio
Theres a lash chart in the tech archives, setting the lash is easy.
Valve Adjusting Chart (90 degree method)
[Re: Von]
#596037
01/30/10 03:11 PM
01/30/10 03:11 PM
Posts: 16,923 NC
440Jim
NC
This is what I measured on the MP 0.557" cam (within measurement uncertainty)
.020" 287º .050" 257º (256.5) .100" 222º .200" 165º
Fast68Plymouth posted the 0.590" cam years ago: Quote:
.020" 303.5º .050" 270.5º .100" 235.0º .200" 177.0º
Ultradyne 0.050"/0.200" _____NF57 255/172 _____NF64 271/188
