What size bolts go on the manual tranny pan? #59579
05/19/08 12:55 PM
05/19/08 12:55 PM
BigAg Offline OP
BigAg  Offline OP
I want to attach the pan to the underside of my manual transmission. This is for a 71 charger with a 440 engine. I figured out what thread bolts i need but don't know the correct length. I suspect some of the holes may have dirt in them which is preventing me from a trial and error method. I looked in my manual but it only tells me the correct thread and not length.
Re: What size bolts go on the manual tranny pan? [Re: BigAg] #59580
05/19/08 01:34 PM
05/19/08 01:34 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
http://www.brewersperformance.com/proddetail.asp?prod=DCB&cat=225
These are the correct bolts for the bottom cover of the bellhousing. They are 5/8" long. You can also use oil pan bolts.
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
