Help trouble code PO420 #59575
05/19/08 12:54 PM
05/19/08 12:54 PM
NY usa
540challenger Offline OP
NY usa
I have one of my work vans with the Code PO420. As far as i could tell it is a bad cat. How could i should i procede in troubling shooting this. Scanner reads PO420 catayst system efficiency below threshold ( Bank 1) So do i have 2 cats since it is on back 1 i have to go under and check in a little bit.
Re: Help trouble code PO420 [Re: 540challenger] #59576
05/19/08 01:51 PM
05/19/08 01:51 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
that can also be your post-cat/downstream oxygen sensors. in most cases the codes will give you a direction, and not quite just what part to replace.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Help trouble code PO420 [Re: GoodysGotaCuda] #59577
05/19/08 02:01 PM
05/19/08 02:01 PM
cousinbob Offline
cousinbob  Offline
Sent you an email. Send me the info on the vehicle so I can give you some help.
Re: Help trouble code PO420 [Re: cousinbob] #59578
05/19/08 02:18 PM
05/19/08 02:18 PM
NY usa
NY usa
Thanks i am at work i will sned you an e-mail when is get home aroun 4:00 thanks
