68-9/70 brake lines. #59563
05/19/08 12:24 PM
05/19/08 12:24 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
you learn something everyday. Anybody know why the rear brake lines on a 70 8.75 would be differnt than a 68? Did a rear swap this weekend bought a new set of fine line rear lines and...they no fit! had to use an old set (lucky they were still nice.
Re: 68-9/70 brake lines. [Re: Mr.Yuck] #59564
05/19/08 01:34 PM
05/19/08 01:34 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
what line didn't fit ?
Re: 68-9/70 brake lines. [Re: JohnRR] #59565
05/19/08 01:58 PM
05/19/08 01:58 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
The fine lines fit the 8.75 that was in the car (70 Charger) but the rear I was putting in was from a 68 RR. I just cleaned up and re-used the original lines. (68 rear) The "T" block is in a different place. Now I have to ask myself, do I buy a hose for a 70 Charger or a 68 RR???
Re: 68-9/70 brake lines. [Re: Mr.Yuck] #59566
05/19/08 02:42 PM
05/19/08 02:42 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
depends , is the body line stop in the same spot for a 68 rr as a 70 charger .
they did the same thing on a bodies , maybe the same year , moved the T block , i redrilled and tapped the axle to put the line in the proper place for the car i was working on as i am pretty sure the line is listed as different also
Re: 68-9/70 brake lines. [Re: JohnRR] #59567
05/19/08 02:44 PM
05/19/08 02:44 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
No idea but I do have access to a few nice 68 RR's . I'll have to do a little looking.
