Who Has the Best E Body Vert Lift Cylinders ??? #593855
01/25/10 07:35 PM
01/25/10 07:35 PM
Renton, Wa.
Classof70Chally Offline OP
super gas
super gas
Renton, Wa.
While removing my carpeting for replacement I noticed one of my vert top lift cylinders leaking. It's leaking at a fitting as well as the shaft itself. As long as I have the rear panels off for access I'm going to replace both cylinders. Does any sponsor/member here sell these ? Thanks
Re: Who Has the Best E Body Vert Lift Cylinders ??? [Re: Classof70Chally] #593856
01/25/10 08:06 PM
01/25/10 08:06 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Hydro-Electric is the usual supplier but on E bodies the cheap way is to grab a pair of cylinders off a K-car vert.. They are probably getting harder to find these days but back when I built my vert they were cluttering the local Pick-n-Pulls & a pair of cylinders was $20.00...
Re: Who Has the Best E Body Vert Lift Cylinders ??? [Re: 1_WILD_RT] #593857
01/25/10 10:30 PM
01/25/10 10:30 PM
NW Ohio
6pkaar Offline
6pkaar  Offline
NW Ohio
Doesn't it have to be an early K-car?
Re: Who Has the Best E Body Vert Lift Cylinders ??? [Re: 6pkaar] #593858
01/26/10 01:20 AM
01/26/10 01:20 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Any of the Boxy style.. The rounder ones at appeared around 1990 are different but I don't really think of those as K cars... I just think of them as Lebarons...
Re: Who Has the Best E Body Vert Lift Cylinders ??? [Re: 1_WILD_RT] #593859
01/26/10 01:51 PM
01/26/10 01:51 PM
Renton, Wa.
super gas
super gas
Renton, Wa.
I found a company called convertible service on the web that makes them. The cylinders on my car are cheap looking crimped aluminum with plastic heads where the lines connect at the top. This company uses steel cylinders with cast steel heads. A much better looking unit. They are not cheap at $140 ea but I only want to do this once. Thanks for the tips.
Re: Who Has the Best E Body Vert Lift Cylinders ??? [Re: Classof70Chally] #593860
01/26/10 03:25 PM
01/26/10 03:25 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
