Window net Install #593246
01/24/10 10:21 PM
01/24/10 10:21 PM
NC
chris3 Offline OP
chris3  Offline OP
NC
Our new window net.
Re: Window net Install [Re: chris3] #593247
01/28/10 05:10 PM
01/28/10 05:10 PM
NC
chris3 Offline OP
chris3  Offline OP
NC
The loop at the front is made from a stainless steel rod and is welded to the roll cage. The rod through the bottom of the net is a stainless steel rod (painted). The strap that holds tension on the front is a strap from a childs safety seat. The second post that I made, on the same day, is a photo from the strap mount.
The top bar and the latch is from a window net kit I had bought. The previous mounting would not fold down, out of the way, as this new mounting does.
