Holley rebuild kit? #59210
05/18/08 05:06 PM
05/18/08 05:06 PM
Iowa
3
318Bruiser Offline OP
Iowa
Which kit does anyone recommend for rebuilding a Holley 600 #1850? Doing a stock rebuild. Where would you recommend buying the kit from?
Re: Holley rebuild kit? [Re: 318Bruiser] #59211
05/18/08 05:31 PM
05/18/08 05:31 PM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
The Holley Part No. for the standard rebuild kit for your carb is 37-119. Summit sells them for about $22. I like to support the local shops so I just had one ordered through one of the local auto parts stores. Cost a few dollars more but I don't want to see the day that all the local guys close up shop due to internet pricing.
Good luck with your rebuild. I'm putting mine back together today.
Re: Holley rebuild kit? [Re: 318Bruiser] #59212
05/19/08 10:09 AM
05/19/08 10:09 AM
dogdays Offline
dogdays  Offline
Whatever kit you get be sure you get the non-stick gaskets. I got mine at Autozone because it was in stock. Probably paid $28. I put the rebuilt carb on my $500 ford pickup.
On that 1850 the rear bowl covers the metering plate. You will need a clutch head screwdriver to get the metering plate off, I think it's a #2 but be assured there is only one that fits and those screws can be a [Edited by Moparts - Keep it clean] to get out. There is a gasket that goes under the metering plate and it will get ruined when you dunk the carb in cleaner. So, you have to take the plate off.
R.
Re: Holley rebuild kit? [Re: dogdays] #59213
05/19/08 01:32 PM
05/19/08 01:32 PM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
I was actually able to use a small flat blade screwdriver to remove the clutch head screws without any problems and without boogering up the screws. For me, the biggest PITA was trying to buy a clutch head screwdriver.
The 37-119 kit that I referenced earlier has the non-stick (blue) gaskets in it.
Re: Holley rebuild kit? [Re: rss] #59214
05/19/08 03:21 PM
05/19/08 03:21 PM
dogdays Offline
dogdays  Offline
Can't believe that I got edited! I believe that's the first time.
I used the small flat blade driver too but nearly lost one of the screws, I finally got it out with a Vice Grips! The clutch head screwdriver either came from Ace or Tool King.
I'm seriously thinking about button socket-head capscrews to replace.
R.
Re: Holley rebuild kit? [Re: dogdays] #59215
05/19/08 04:37 PM
05/19/08 04:37 PM
Iowa
3
Iowa
Ya, a flat head screwdriver worked good for taking that off for me. I checked yesterday and the kit was only $22 which was the cheapest I seen. Hope it doesn't go up next week when I get paid.
