B body 10 in.to 11 in .front drum swap question.??? #59101
05/18/08 12:00 PM
05/18/08 12:00 PM
Penna
70satelliteguy Offline OP
Penna
My 68 Chargers front 10 in. drum amd hubs are shot. I have a friend who has a complete set of 11 in. drums/backer plates for sale cheap. Will the 11 in. setup swap over to the spindles that held the 10 in. setup or must I change the spindles also?
Thanks MIke
Re: B body 10 in.to 11 in .front drum swap question.??? [Re: 70satelliteguy] #59102
05/18/08 12:13 PM
05/18/08 12:13 PM
NY
twodoorpost Offline
twodoorpost  Offline
NY
Same spindles. Just swap matching backing plates, drums & hardware.
Re: B body 10 in.to 11 in .front drum swap question.??? [Re: twodoorpost] #59103
05/18/08 12:20 PM
05/18/08 12:20 PM
Penna
Penna
Thank you 2 door!!!!
Mike
Re: B body 10 in.to 11 in .front drum swap question.??? [Re: 70satelliteguy] #59104
05/20/08 01:01 AM
05/20/08 01:01 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
They should swap, but use the hardware for a 1970 because they had self adjusters, the 1969's and earlier did not have self adjusters.
Re: B body 10 in.to 11 in .front drum swap question.??? [Re: 451Mopar] #59105
05/20/08 03:28 PM
05/20/08 03:28 PM
Penna
Penna
I just did the swap this morning. Pretty easy and everything seemed to fit fine. Now I just have to wait till my wife gets home to bleed the brakes and off I go for a road test!!
Thanks for the help guy's
Mike
Re: B body 10 in.to 11 in .front drum swap question.??? [Re: 70satelliteguy] #59106
05/20/08 04:11 PM
05/20/08 04:11 PM
central new york
pettyblue440 Offline
central new york
you should notice quite a difference in braking power. my brother did the same swap last year
Re: B body 10 in.to 11 in .front drum swap question.??? [Re: pettyblue440] #59107
05/20/08 09:42 PM
05/20/08 09:42 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
just the fronts over to 11" and left the rears smaller.
Re: B body 10 in.to 11 in .front drum swap question.??? [Re: JohnRR] #59108
05/21/08 11:11 AM
05/21/08 11:11 AM
mikemotorhead Offline
super street
super street
"just the fronts over to 11" and left the rears smaller. "
Probably wont be as dramatic as converting to front discs and leaving the drums the same! Lots of conversions being done without issues!
Re: B body 10 in.to 11 in .front drum swap question.??? [Re: JohnRR] #59109
05/21/08 07:38 PM
05/21/08 07:38 PM
central new york
central new york
oops, i missed that detail, my brother went all 11" at all 4 corners
Re: B body 10 in.to 11 in .front drum swap question.??? [Re: pettyblue440] #59110
05/22/08 07:54 PM
05/22/08 07:54 PM
Penna
Penna
The road test is complete on my Charger. The brakes work GREAT! There were absolutely no issues with nose dive or anything else other than the car stops better than it had before!
Thanks all Mike
