reupolstering buckets seat 70 b-body? #59088
05/18/08 10:23 AM
05/18/08 10:23 AM
weymouth,mass.
meepmeep70 Offline OP
weymouth,mass.
redoing a front bucket seat,replacing everything including the burlap, question is where can i find or buy the very thin wire that weaves through the burlap,some of mine where broken or rusted out? are the absolutly nessacery? thanks for any help or direction
Re: reupolstering buckets seat 70 b-body? [Re: meepmeep70] #59089
05/18/08 12:00 PM
05/18/08 12:00 PM
weymouth,mass.
weymouth,mass.
someone must have had this problem before NE1?
Re: reupolstering buckets seat 70 b-body? [Re: meepmeep70] #59090
05/19/08 05:21 PM
05/19/08 05:21 PM
weymouth,mass.
weymouth,mass.
,just thought i'd try one last time
Re: reupolstering buckets seat 70 b-body? [Re: meepmeep70] #59091
05/19/08 05:33 PM
05/19/08 05:33 PM
Phoenix, AZ
3
38371cuda Offline
38371cuda  Offline
Phoenix, AZ
I do not know where to buy the two side wires(called lists). I have used coathangar wires as well as 1/8 steel rods purchased from HD or lowes for mine. If doing the back, be sure to get the 48" rods while the seat bottom you can get away with the 36". They cost about $2-3 ea. Be sure to curve the ends away from the new upolstery like the factory did. Hope this helps.
Re: reupolstering buckets seat 70 b-body? [Re: 38371cuda] #59092
05/19/08 05:39 PM
05/19/08 05:39 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
Though not absolutely necessary, I used welding rod. Although my upholsterer said I was way too anal; that they always just used new burlap all doubled up and stretched tightly.
Re: reupolstering buckets seat 70 b-body? [Re: 469runner] #59093
05/19/08 08:23 PM
05/19/08 08:23 PM
At a gas station near you
badblack68 Offline
badblack68  Offline
I used several pieces of 1/8" stainless tig wire on my 70 GTX.
Re: reupolstering buckets seat 70 b-body? [Re: badblack68] #59094
05/19/08 09:46 PM
05/19/08 09:46 PM
weymouth,mass.
weymouth,mass.
thank you guys for your help ,now i can get these seats done
Re: reupolstering buckets seat 70 b-body? [Re: badblack68] #59095
05/19/08 09:50 PM
05/19/08 09:50 PM
Dayton, Ohio
65cuda Offline
mopar addict
65cuda  Offline
mopar addict
Dayton, Ohio
you don't need the small wires in the cloth. i just double up with cloth first. ring that in then the foam. you do need the listing wire. they are usally fine but you can make them from 1/8 welding rod.
Lengendary sells the cloth by the yard and use to include enough with a set of covers. better than burlap.
65 Cuda 360,3.23 SG-13.97 @99.4, 88 D100, 2000 Kota Qcab, 71 Duster 416 11.84 @110., 73 Imp ,(2)72 & (1)71 Dart Swingers
GarysMocars Legendary Dealer
