3.23's behind a 440 #59053
05/18/08 12:30 AM
05/18/08 12:30 AM
North Dakota
440abody Offline OP
440abody  Offline OP
North Dakota
I probably have a dumb question, but here it goes. I have a 73 Dart with a 440/727. The engine is built as follows, 30 over, balanced, a true 10.1 c/r, Eddy heads, Eddy torker II intake, Holley 770, and a Comp 275 Dual energy cam. So the question is, are a set of 3.23's in in a 742 case strong enough to last with this combination? By the way the car is 100% street driven and I live in North Dakota. It's 50 miles to get any where around here so, the 3.23's are the gear of choice/neccesity.
73 Dart Swinger 440/727 8.75 w/3.55's
34 Ford 3w coupe with a soon to be 1958 392HEMI!
Re: 3.23's behind a 440 [Re: 440abody] #59054
05/18/08 06:03 AM
05/18/08 06:03 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Yes. It should live a long and happy life
Re: 3.23's behind a 440 [Re: BSB67] #59055
05/18/08 06:41 AM
05/18/08 06:41 AM
Rochester, NY
dusterdood Offline
dusterdood  Offline
Rochester, NY
Especially with street tires.
Re: 3.23's behind a 440 [Re: dusterdood] #59056
05/19/08 11:30 AM
05/19/08 11:30 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
We have well over 30,000 miles on a mild 440/4sp/3.23 8-3/4 setup that's in my son's Dart convertible. It may even be a 741 case and it DOES have the small u-joint. Never have had a driveshaft or rear end related issue with the car. Purely street driven with no traction aids (except the Sure Grip).
Re: 3.23's behind a 440 [Re: 440abody] #59057
05/19/08 11:47 AM
05/19/08 11:47 AM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
In that little car with the big TQ. you have,
it would roast the tires with any gear you have.
The 3.23s will last a long time on the street.
For better hyway driving I would go with a
3.08 and it would still be an animal!!!!
Snap your neck, mega G-force launch, is all I want!
