Bought a new car (1970 Super Bee)
#59032
05/17/08 09:35 PM
05/17/08 09:35 PM
Re: Bought a new car you guys are the first to see it.
#59033
05/17/08 09:36 PM
05/17/08 09:36 PM
Right on man!!
Re: Bought a new car (1970 Super Bee)
#59036
05/18/08 12:53 AM
05/18/08 12:53 AM
Posts: 4,247 Alabama
BigMoneyLewis
Alabama
The stripe options are V6__ = C stripe, or V8__for the bumblebee stripe . The missing 3rd digit is the color of the stripe. Or if the last digit is an 8, it was a stripe delete . That's the wrong air cleaner base by the way, but you probably already knew that. Greg Wards Classic Car Radio Repair Specializing in restoration and sales of Mopar A B E body radios We can restore YOUR radio usually in less than 7 days Visit our NEW website.. http://www.wardsclassiccarradiorepair.comgregward@mchsi.comphone 256-852-0955
[Re: BigMoneyLewis]
#59037
05/18/08 07:38 AM
05/18/08 07:38 AM
yea I kind of figured it was the wrong air cleaner, but didnt know for sure because it looked weird. Do you know what car the air cleaner is from?
#59043
05/18/08 07:10 PM
05/18/08 07:10 PM
Posts: 20,740 A collage of whims
topside
A collage of whims
Nice find, congratulations! I agree with the Magnums, or 15" Rallyes, if you want a stock look. I see some weirdness on the firewall, and with the dash vents, I wonder if it was an A/C car with the firewall converted to non-A/C. I don't think the center vents would be standard equipment in '70. The ft seats are '68 Charger, and worth some $$$ if they're nice. Ditto the 440 Six-Pak setup if you decide to swap a 383 back in. Were the Rallye gauges standard in '70, or were they optional? If you don't mind a suggestion, the ignition coil's mounted in a high-heat area.
[Re: Y3 70 BEE]
#59045
05/18/08 09:59 PM
05/18/08 09:59 PM
yea, that makes sense since the interior must be from the same 68' Charger.
The guy told me the interior was completely trashed and he bought all the charger stuff from a parts car, I just didn't know that cluster stuff was also from a charger. He also hacked the [Edited by Moparts - Keep it clean] out of the firewall trying to install that ac motor. It looks absolutely terrible. I'm probably going to rip it out and weld a patch panel in there.
I knew the car was not 100% original/correct, if it was I probably couldn't afford it.
Thanks for the heads up guys.
[Re: Quikshft]
#59047
05/19/08 02:09 AM
05/19/08 02:09 AM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
Why the H LL do people start theads, get replys and then can them? EDIT: Nice find Glad I got to see the pics
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
[Re: R70RUNNER]
#59048
05/19/08 02:36 AM
05/19/08 02:36 AM
sorry, changed the host..
#59049
05/19/08 09:14 AM
05/19/08 09:14 AM
Posts: 3,407 S.E. Florida, USA
rrunner
S.E. Florida, USA
Looks like you have a charger instrument cluster and there is no woodgrain on the dash. All 70 bees have the woodgrain dash.
All of the interior (seats etc) are from a charger I was told. so the trim on the dash is also from a charger??? Or the whole dash?
Because I know the previous owner told me the dash was taken out to put in the ac blower motor. Because I don't believe the car had AC originally and the guy wanted it installed.
Looks like it has the 68 lower pads as 70 had plastic. Where is the ign switch? 70 is on the column 68/9 on the dash.
[Re: rrunner]
#59051
05/19/08 11:59 AM
05/19/08 11:59 AM
the ignition switch is on the column.
#59052
05/19/08 02:24 PM
05/19/08 02:24 PM
rrunner
S.E. Florida, USA
Are the lower pads & glove box door plastic?
