Zeeker Heads Flow Numbers #590148
01/21/10 03:48 PM
01/21/10 03:48 PM
SD800 Offline OP
SD800  Offline OP
Had my heads flowed by Barnett Performance, the intake flowed 375CFM and the exaust was 220CFM both at .700 inch lift.
The intake lost 5 cfm between .700 and .800 lift but the exaust continued to improve
I would like to stay around .700 lift can the exaust be improved to flow more at .700
You'll have plenty of time to sleep when your dead, let's go
Re: Zeeker Heads Flow Numbers [Re: SD800] #590149
01/21/10 03:55 PM
01/21/10 03:55 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
I don't have much to add here, but I want to say that those seem like pretty good numbers for those heads. I imagine that they have been extensively ported? Any pics?
Re: Zeeker Heads Flow Numbers [Re: SD800] #590150
01/21/10 04:07 PM
01/21/10 04:07 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I would imagine that the exhaust could be improved. I have those type of exhaust numbers in my home ported 915's
IIRC they should have a 75% ratio intake to exhaust.
Great numbers on the intake
Re: Zeeker Heads Flow Numbers [Re: SD800] #590151
01/21/10 06:57 PM
01/21/10 06:57 PM
Woodstock , Georgia
Mopar_racer_99 Offline
Woodstock , Georgia
Who ported the heads, they should flow equal to fully ported -1 heads since Loren's heads were the predecessors to them. John
8.72 @ 154.6 ,68 Charger 578ci 440-1s, 3000# w/drvr, 2150 den/alt NA
Re: Zeeker Heads Flow Numbers [Re: SD800] #590152
01/21/10 10:12 PM
01/21/10 10:12 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Those sound great..
What needs to be asked is, if the flow bench operator used a tube or not on the exh side..
That can easily move them up a good 25% in flow or close to it..
