STOP on a dime? NOT! (UPDATE)
#58975
05/17/08 06:10 PM
05/17/08 06:10 PM
in my 22 years as a mechanic.. never ever ran into this kinda problem. so here goes....
1997 neon, replaced the front pads, adjusted up the rear shoes and whoa, no pedal. changed the master cylinder (bench bled), bled the brakes, still no pedal. changed the m/c again, still no pedal. checked all the lines, wheel cylinder etc, no leaks. bled them a 3rd and 4th time, still no pedal. when i mean no pedal.. i mean right to the floor. what the heck is going on here?
Re: STOP on a dime? NOT!
#58976
05/17/08 06:23 PM
05/17/08 06:23 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
I've seen on these fwd chryslers, that it is very important to have a wheel nut holding the rotors in place when you put the calipers back on. If not, it's easy for it to be installed cocked off to one side. Looks fine, but's it's crooked. The pedal travel is all taken up straightening it back out again. The guy who did it in my shop had 30 plus years of trade experience, so it can happen to anyone. Something to check anyway.
#58977
05/17/08 06:24 PM
05/17/08 06:24 PM
Posts: 32,909 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
Start from the begining. What happened to need the brake swap? When you say no pedal does that mean it never pumps up or what?
[Re: stumpy]
#58978
05/17/08 06:28 PM
05/17/08 06:28 PM
just came in cause the pads where worn out. still had lots of pedal. changed the front pads, the brake pedal went right to the floor, i told my helper its normal, and just pump up the brakes. but they would not pump up. they just go right to the floor. Dave571.. did the wheel nut to hold the rotor thing. thanks
#58979
05/17/08 06:29 PM
05/17/08 06:29 PM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
I was sure it was the wind....
A new iron curtain drawn across the 49th parallel
[Re: stumpy]
#58981
05/17/08 06:36 PM
05/17/08 06:36 PM
yah, there was enough there to hold the wheels. front and back. i also adjusted the rear shoes up. i visually looked to see if the calipars and wheel cylinders were moving, they were.
#58982
05/18/08 08:20 AM
05/18/08 08:20 AM
Posts: 21,063 Niles , Ohio
therocks
Niles , Ohio
Had an Itntepid at work with the same kind of problem.New pads all around and no pedal.Installed new master as it was bad still no pedal.It was the PP valve that is for non ABS brakes only.Couldnt get any pressure or fluid especially the rears.A new block from dealer and great brakes.Rocky
Chrysler Firepower
[Re: therocks]
#58983
05/18/08 08:33 AM
05/18/08 08:33 AM
Posts: 27,728 places
79powerwagon
places
Maybe I'm too anal about brakes, but this is why when my brakes are about 5-7 years old and needing a pad change, I simply dive in and replace the ENTIRE brake system, including hard and soft lines. Yes, it's bucks, but it sure eliminates the frustrations kinda like you're going through now! Of course, you say this is a customer's car, so they won't want to cough up the ching to do it, but for my personal vehicles, this is what I always do. Money well spent, in my opinion!
#58985
05/18/08 10:50 AM
05/18/08 10:50 AM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Almost sounds like your master is too small. The first one may have been damaged or got something in the piston cup to cause the master bypass and go bad but the replacements do not have enough volume to pump up the brakes. After a couple quick pumps does the pedal come up? I've always heard but never experience that if you push too much or too hard when bleeding the master you could damage it. Another thing could be a big air buble in the system that got pushed in when the master was replaced. On some cars this air can be a total pain to remove with out pressure bleeding. Are you using a power bleeder or manually bleeding it? Good luck
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HealthServices]
#58986
05/18/08 11:24 AM
05/18/08 11:24 AM
pedal woudn't come up no matter what. and yah.. manually bleeding it, no power bleeder. if theres still air in it, its hiding pretty good . i'll try gravity bleed it today, if that fails, then i'll change porportioning valve. stupid neon messing up my whole long weekend
[Re: DoctorDiff]
#58988
05/18/08 11:38 AM
05/18/08 11:38 AM
well they face to the "side". otherwise they are at its highest point.
#58989
05/18/08 12:09 PM
05/18/08 12:09 PM
Posts: 2,496 God's Country Maryland
GODSCOUNTRY340
When you compressed the pistons did you loosen the bleeders to relieve the pressure or force it back into the MC? If you forced it back to the MC you may have damaged the proportioning valve. Just a thought.
#58990
05/18/08 01:59 PM
05/18/08 01:59 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Got ABS?
If so there is a specific method to bleed them, the regular old style doesn't do it.
[Re: Supercuda]
#58991
05/18/08 05:49 PM
05/18/08 05:49 PM
no abs. tried everything today, including replacing the p-valve. result? same thing this thing is gonna be the death of me. did 100's of brake jobs.. replace the front pads, adjust the rear drums, out the DOOR no problem. this thing is driving me gonna save it to tuesday, get a vacuum bleeder and try again. thanks for the help everyone
#58992
05/18/08 06:34 PM
05/18/08 06:34 PM
Posts: 292 dead center
CHRONiklyDEMONic
Demonized
Demonized
dead center
Trial and error. There are only a number of components. Check, check again, and then recheck.
Remember, NEVER count on "new parts" to be in working order, no matter what the box says.
Good luck, let us know what happens.
"After a Day filled with burning Rubber, you may find it time to re-tire."
[Re: RobR]
#58994
05/18/08 07:43 PM
05/18/08 07:43 PM
CHRONiklyDEMONic.. i know never to trust "new" parts.. i will keep yall posted tho. RobR.. damn near replace everything twice or three times (master cylinder). Its gotta be air somewhere.. even tho the brakes bleed normally (ie: no air coming out). m/c checked out just peachy. It started out as a simple 15min change the pad thing.. which is now on day two.
