HOW would U build the perfect traveling STREETROD? #58808
05/16/08 08:33 PM
05/16/08 08:33 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
I am more than likley going to get this 38 Plymouth. I chose it because it has lots of room compared to the little 32 I used to have. I want it very vey drivable. So I am planning on doing a 5.7 HEMI for the looks and drivability. I want and a must have is air conditioning and confort.
So that said, and no real budget in mind what would you do. What suspension and what after market air, what wiring, what engine, ect. I really dont care about huge horse power, I have CUDAS for that and a 67 dart that will be very quick.
I want a car that I can drive across country if need be. A car that the wife will enjoy and drive as much as me.
HOW WOULD YOU BUILD IT AND WHAT COMPANIES WOULD USE USE????? GIVE ME SOME IDEAS.
LAWFISH
Re: HOW would U build the perfect traveling STREETROD? [Re: RUMBLON] #58809
05/17/08 02:01 AM
05/17/08 02:01 AM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
I would get a fatman frontend (mustang II style).with the 11" big brake setup, a 5.7 hemi with a 5 speed auto with a B body 8 3/4 rearend with 3.23 or 3.55 gears.
vintage air is a good unit but southern air makes some nice ones too.
the only issue is getting the wiring for the Hemi, I haven't done one yet and they look like they are expencive
, that should make a great daily driver or cross country car
I built a 37 dodge sedan for a friend years ago and I used the must II frontend and 8 3/4 rear and used a 360 2bbl/727 and that was a great cruiser car Ron....
Re: HOW would U build the perfect traveling STREETROD? [Re: Mopar Ron] #58810
05/18/08 12:07 AM
05/18/08 12:07 AM
Hawley, Texas
shinnery Offline
super street
shinnery  Offline
super street
Hawley, Texas
Ron, Is a 8 4/4 rearend the same as a 9"?? LOL
Bryce
Every electronic device is manufactured with smoke stored deep inside... only a true genius can find a way to set it free. The most terrifying words in the English language are: "I'm from the government and I am here to help!"
Re: HOW would U build the perfect traveling STREETROD? [Re: shinnery] #58811
05/18/08 12:15 PM
05/18/08 12:15 PM
Mopar Ron Offline
Mopar Ron  Offline
Bryce
OK,OK I fixed it, thats what I get for not reading it a second time
yeah that would make it 9" rearend Ron..
Re: HOW would U build the perfect traveling STREETROD? [Re: Mopar Ron] #58812
05/19/08 10:37 AM
05/19/08 10:37 AM
dogdays Offline
dogdays  Offline
Ron is right about the front end and rear. I would disagree with him about the engine. I'd suggest a 5.2 Magnum which will make decent power, get good mileage and be quite a bit easier to swap electronics-wise.
R.
Re: HOW would U build the perfect traveling STREETROD? [Re: dogdays] #58813
05/19/08 10:46 AM
05/19/08 10:46 AM
East Lansing, Michigan
O
OldHippie Offline
super gas
OldHippie  Offline
super gas
O
I would agree on the suspension mods for good driveability/comfort and lean towards the 5.2 Mag. engine with an OD trans for fuel economy. About the rear end.....there are a ton of 8 1/4-8 3/8 units out there that would make a killer set up for this type of car. As long as you are not pounding on it with a high HP power plant it would work just fine and be much cheaper than a 9" or an 8 3/4.
Just my worth.
The Old Hippie Hisself
Re: HOW would U build the perfect traveling STREETROD? [Re: OldHippie] #58814
05/19/08 12:54 PM
05/19/08 12:54 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Just my worth.
I have two B body 8 3/4 rear ends. Any idea how much has to be cut to make these work?
Re: HOW would U build the perfect traveling STREETROD? [Re: RUMBLON] #58815
05/19/08 01:37 PM
05/19/08 01:37 PM
Mopar Ron Offline
Mopar Ron  Offline
the cars that I did, they fit right in, of course it would make a difference depending on what size tires you want to run. Ron...
Re: HOW would U build the perfect traveling STREETROD? [Re: dogdays] #58816
05/19/08 02:05 PM
05/19/08 02:05 PM
Mopar Ron Offline
Mopar Ron  Offline
R.
I agree with you guys about the 5.2 magnums, the only reason I said 5.7 hemi is that Dave was leaning towards one of them that he can get a deal on.
I think either of them would make a good cruiser setup but electronics would be harder with the new hemi. Ron...
Re: HOW would U build the perfect traveling STREETROD? [Re: Mopar Ron] #58817
05/19/08 05:49 PM
05/19/08 05:49 PM
Thayer, MO
bohmer2 Offline
bohmer2  Offline
Thayer, MO
Electronics are getting easier by the day on the new hemi's if you have an ECU and a wiring harness for the new hemi you can get it flashed and run a drive by wire and its not that tough. The 5.7's are still a little more expensive than the 5.2/5.9 but they are getting closer and closer by the day.
If I am buying it Dave, I would go with the Fatman frontend if I am fabbing it up (like I got with my 39 Plymouth and with what I am looking at for my 48 Panel) I am going Dakota.
If you change to the dakota and the 5.2/5.9 the motor mounts/geometry are already there you just need to see if you can get the engine placement to work with your firewall. I am using a 5.7L that I just picked up a couple weeks back but I haven't decided what to do about the electronics because I am leaning towards a 392 stroker kit, with 6.1 heads and would like to put a traditional looking intake and throttle body (XV has a nice one) on the car. The Tranny I have now is a 518 OD four speed but I am see if I can find a 5spd od auto for it. Electronics wise, I visited Speed and Performance in Mena, AR a month or so ago when I was down there for work and they know their stuff and have been some of the first to do these transplants. But at the same time, XV seems to be doing more with modified motors, while I have also seen a transplant of a 5.7 in a dakota where the guy did all the wiring himself combining harnesses from both the dakota and the 5.7 donor truck. I am not a wiring guru so this seemed daunting to me, so I will be buying a kit and I heard that there are a couple of guys that do most of these kits that the retailers are selling and you can buy straight from them.
Rear end wise I am either using a dakota 8 1/4 (which I will need to convert for the current six lug back to the five lug with axles etc) or I am thinking about a FORD 8.8 out of a Explorer or Mustang to get the 3.73 gears and rear disk brakes but I am also thinking an early 90's Grand Cherokee would have the same gears and disk brakes (may depend on what the yards have when I go look), either can be provisioned to give you an e-brake pretty easily. But I also need to figure out what width rear I want to end up running because there is a ton of room in those fenders so it may be possible to run 10" or 12" wides if I can find the right offset without narrowing the rear-end.
I am right behind/ahead of you with this same build Dave, I am dealing with a 39 Plymouth 4 dr but I want it to be a comfortable cruizer that I can take across country if the urge hits. I am lucky enough to already have the front clip done for me so that choice has been made but I am still working out the rest. I just want to be sure if necessary I can pull into just about any town and get the parts for the drive train if it brakes down.
Re: HOW would U build the perfect traveling STREETROD? [Re: bohmer2] #58818
05/20/08 02:50 AM
05/20/08 02:50 AM
Hawley, Texas
shinnery Offline
super street
shinnery  Offline
super street
Hawley, Texas
Haven't the Durangos come with 5.7Ls for several years now? Get one of them and use the chassis and all the wiring is already there. Might be a problem with instruments unless you use the Durango IP.
Bryce
Re: HOW would U build the perfect traveling STREETROD? [Re: RUMBLON] #58819
05/20/08 04:10 PM
05/20/08 04:10 PM
Montana
FuryUs Offline
FuryUs  Offline
Montana
If you're concerned about mileage, I'd skip the Magnum 318 or 360 unless you're going with a well-tuned carb or aftermarket EFI.
Re: HOW would U build the perfect traveling STREETROD? [Re: shinnery] #58820
05/21/08 09:01 AM
05/21/08 09:01 AM
Thayer, MO
bohmer2 Offline
bohmer2  Offline
Thayer, MO
Bryce
The Gen II Durango's do come with 5.7s, what I am not sure about is the track width of the front end and how it would compare to the 38 plymouth.
Re: HOW would U build the perfect traveling STREETROD? [Re: bohmer2] #58821
05/21/08 10:04 AM
05/21/08 10:04 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
How would this 38 Plymouth look in a plum crazy or maybe even a curious yellow???? any suggestions on a color.
Re: HOW would U build the perfect traveling STREETROD? [Re: FuryUs] #58822
05/22/08 02:01 AM
05/22/08 02:01 AM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
I think even the 5.7 gets a bad rap for mileage...if you're talking to a truck owner. Push 6K+ pounds around and the mileage, and power, really doesn't impress. The 5.7's in the car platforms do considerably better than the trucks...why would the 5.2 or 5.9 Mag be any different?
2 Demons...no, not my kids!
