FUEL LINES & BRAKE LINES #58731
05/16/08 10:57 AM
05/16/08 10:57 AM
Richmond, VA
rayztoy Offline OP
rayztoy  Offline OP
Richmond, VA
Hi Guys,
Where can I source these items, as closest to OEM in fit and quality? Thanks.
Ray
Re: FUEL LINES & BRAKE LINES [Re: rayztoy] #58732
05/16/08 12:40 PM
05/16/08 12:40 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
I really like FINE LINES...excellent quality and fit in my opinion
CHECK OUT MY NEW WEB SITE !
Re: FUEL LINES & BRAKE LINES [Re: anlauto] #58733
05/16/08 12:45 PM
05/16/08 12:45 PM
Richmond, VA
rayztoy Offline OP
rayztoy  Offline OP
Richmond, VA
Alan,
Thanks for the advice. Now do they make both the brake and fuel lines?
Re: FUEL LINES & BRAKE LINES [Re: rayztoy] #58734
05/16/08 01:48 PM
05/16/08 01:48 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Alan,
Inline tube out of Ohio makes some nice lines. They also have repop splitter blocks, proportioning valves, cables,etc
Re: FUEL LINES & BRAKE LINES [Re: rayztoy] #58735
05/16/08 01:51 PM
05/16/08 01:51 PM
anlauto Offline
anlauto  Offline
Alan,
Yes..They have EVERYTHING you will need. I've bought SEVERAL sets in the past 5 years and have never had any issues
Re: FUEL LINES & BRAKE LINES [Re: anlauto] #58736
05/16/08 04:42 PM
05/16/08 04:42 PM
Richmond, VA
rayztoy Offline OP
rayztoy  Offline OP
Richmond, VA
Did you go with stainless or OEM? Guys, THANKS!
Re: FUEL LINES & BRAKE LINES [Re: rayztoy] #58737
05/16/08 11:15 PM
05/16/08 11:15 PM
anlauto Offline
anlauto  Offline
I've used both
Re: FUEL LINES & BRAKE LINES [Re: rayztoy] #58738
05/16/08 11:19 PM
05/16/08 11:19 PM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
Stainless looks great and last forever, but some people have problems with them sealing because they are so mouch harder than the brass blocks they screw into. If I use them, I usually "seat" them then back off the nut and seat them a couple times to "form" the brass into the line. OE steel is fine also, it just will not look as good as the stainlessin time and corrosion is a possibility. For a limited use driver or show car OE would be fine-if I were building a car to drive ALOT or it was going to be stored in less than idea conditions I would use the stainless. Also, I have had good luck with Inline tube & Fine Lines-The right stuff doesn't seem to fit very good in my opinion.
Re: FUEL LINES & BRAKE LINES [Re: Paul Jacobs] #58739
05/17/08 07:58 AM
05/17/08 07:58 AM
Richmond, VA
rayztoy Offline OP
rayztoy  Offline OP
Richmond, VA
I'm not sure what you are saying, so could you please clarify. Thanks.
Re: FUEL LINES & BRAKE LINES [Re: rayztoy] #58740
05/17/08 08:38 AM
05/17/08 08:38 AM
Houston, Tx
hemi68charger Offline
Houston, Tx
He's probably referring to the company called "The right stuff"... They make lines.
Troy
Houston Mopar Connection Club
Re: FUEL LINES & BRAKE LINES [Re: anlauto] #58741
05/17/08 09:04 AM
05/17/08 09:04 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Re: FUEL LINES & BRAKE LINES [Re: Paul Jacobs] #58742
05/17/08 09:39 AM
05/17/08 09:39 AM
anlauto Offline
anlauto  Offline
1000%
Re: FUEL LINES & BRAKE LINES [Re: anlauto] #58743
05/17/08 11:21 AM
05/17/08 11:21 AM
Richmond, VA
rayztoy Offline OP
rayztoy  Offline OP
Richmond, VA
Many thanks to all for your feedback!
Re: FUEL LINES & BRAKE LINES [Re: rayztoy] #58744
05/18/08 10:29 PM
05/18/08 10:29 PM
Ohio
dobie Offline
dobie  Offline
Ohio
I've got all new SS brake and fuel lines from Right Stuff Detailing. I'm happy with them.
1968 Plymouth Road Runner 383 4 speed
Re: FUEL LINES & BRAKE LINES [Re: dobie] #58745
05/18/08 10:47 PM
05/18/08 10:47 PM
God's Country - Etowah, TN.
A34 Offline
A34  Offline
I guess it's too late now, but RPM offers a discount of 25% off list for moparts members. www.rpmrestoparts.com.
I got my brake and fuel lines in stainless and love them !
God Bless America, Our Troops and Their Families !
DEO VINDICE
Re: FUEL LINES & BRAKE LINES [Re: A34] #58746
05/19/08 12:36 PM
05/19/08 12:36 PM
Ohio
dobie Offline
dobie  Offline
Ohio
Well, thanks for the tip. I'm sure I'll use them down the road.
Re: FUEL LINES & BRAKE LINES [Re: dobie] #58747
05/19/08 01:25 PM
05/19/08 01:25 PM
Richmond, VA
rayztoy Offline OP
rayztoy  Offline OP
Richmond, VA
Thanks for posting, as I haven't purchased mine yet.
