#58545 - 05/14/08 08:54 PM Cool intake manifold for a 318?
sixpack4spd Offline
Loc: Upstate, NY
I was planning on putting a 451 with a vintage looking weiand 3x2 intake on it in my 46 PU. Lately, I've been considering running a 318 in it. Are there any "vintage" looking intakes you can run on a 318? Anyone add "dummy" carbs to a stock 2bbl intake???
#58546 - 05/14/08 10:15 PM Re: Cool intake manifold for a 318? [Re: sixpack4spd]
Mopar Ron Offline
Loc: Escondido, CA. Ron Podsiadly,...
Back in 76 when I had my 48 morris van, I ran a 318 with a 2bbl on it and I had a gutted out 471 blower case mounted over it and had 2 gutted out carter 4 bbl carbs mountend on top of the fake blower and had the air cleaners on them and had a hilborn scoop on the carbs. I had about $150.00 into the whole thing. I ran a belt gaurd on it so I didn't have torun a belt on it. it looked pretty real
I also thought about running a plate under a 2 bbl carb and mount 2 end carbs to make it look like a tripower Ron.....
#58547 - 05/15/08 09:57 AM Re: Cool intake manifold for a 318? [Re: sixpack4spd]
earlymopar Offline
Loc: Oregon
IMO, the best "vintage' look would be a poly-318 with either the factory 2-4 set-up or the aftermarket 3-2 manifold.
- EM
#58548 - 05/15/08 10:47 AM Re: Cool intake manifold for a 318? [Re: earlymopar]
sixpack4spd Offline
Loc: Upstate, NY
I've got a poly 318 in a parts car but it would need a rebuild. I have a 318/auto out of a 70 Challenger that runs good that I was thinking of using instead of the big block. I really didn't like to looks of the poly motor. I'll probably stick with the big block. I've already got the intake. Maybe I'll just use a mild 383 in it...
#58549 - 05/15/08 10:49 AM Re: Cool intake manifold for a 318? [Re: Mopar Ron]
sixpack4spd Offline
Loc: Upstate, NY
Hmmm, it would be easy to bolt some extra carbs to a plate.
#58550 - 05/15/08 12:54 PM Re: Cool intake manifold for a 318? [Re: sixpack4spd]
dogdays Offline
2-4s on a tunnel ram, shouldn't be that hard to find.
R.
keep in mind that any LA intake will bolt up....................................................................
#58551 - 05/17/08 08:22 PM Re: Cool intake manifold for a 318? [Re: sixpack4spd]
DusterKrazy Offline
Loc: N.Wilkesboro,NC
As a matter of fact...If you go to speedwaymotors.com they have an intake adapter that bolts to a stock 4bbl intake that allows you to run a couple of holley 94's. But really you could use this on any 4bbl intake..
"The perfect LS swap involves a dumpster"
#58552 - 05/20/08 12:14 PM Re: Cool intake manifold for a 318? [Re: sixpack4spd]
Mr.Yuck Offline
Loc: Brookeville, Md
couldn't you just run a 340-6 manifold??? I know the ports are a different size but it seems you don't care much aboout performance so why not?
#58553 - 05/20/08 03:42 PM Re: Cool intake manifold for a 318? [Re: Mr.Yuck]
DTT Offline
super gas
Loc: Imlay City, MI
How many carbs do you want? Are you just after a "look" ?? Offy makes a 2 carb intake setup for 2 4's, AFB style carbs.... The part number is: Offenhauser 5615
1978 Pro Street D100 1936 Dodge truck (Hot rod) 1957 Plymouth Plaza 1962 Chrysler 300 1964 Dodge 440 1995 Jeep Grand Cherokee 1971 Big Block Demon (Dads)
#58554 - 05/20/08 04:57 PM Re: Cool intake manifold for a 318? [Re: Mr.Yuck]
Mopar Ron Offline
I think that the issue is price a 340 6 pack setup can run close to or over $2,000. and just bolting a plate to the 2bbl to make it look like a tri power with the 2 end carbs costing just about nothing at a junkyard, and you keep the economy of the stock 2bbl Ron...
#58555 - 05/23/08 06:23 AM Re: Cool intake manifold for a 318? [Re: Mopar Ron]
85_Ram_4speed Offline
Loc: Truckville, the capital of NY
Something im brewing up for my truck
Outcast Dodge guy.
#58556 - 05/23/08 07:47 AM Re: Cool intake manifold for a 318? [Re: 85_Ram_4speed]
RUMBLON Offline
Loc: Cambridge Idaho
not trying to hikack the thread but I am also interested but want drivability????
LAWFISH
#58557 - 05/27/08 12:49 PM Re: Cool intake manifold for a 318? [Re: Mopar Ron]
Mr.Yuck Offline
Mopar Performance Dual Plane Six Pack Intake Manifolds
Intake Manifold, Dual Plane, Aluminum, Natural, Six Pack, Chrysler/ Dodge/ Plymouth, 318/ 340/ 360, Each.... $299.99
#58558 - 05/27/08 02:02 PM Re: Cool intake manifold for a 318? [Re: Mr.Yuck]
dogdays Offline
The sixpack manifold is the cheap part. By the time you get the carbs and linkage you have a lot more in it than $300!
I'd still go the tunnel ram with two small 4-barrels or 2-barrels. Also with a tunnel ram the older the better as they tended to have smaller runners.
R.
#58559 - 05/27/08 06:12 PM Re: Cool intake manifold for a 318? [Re: Mr.Yuck]
Mopar Ron Offline
yes the intake is $300. but the carbs are around $1,000. (see below) and the air cleaner and linkage and gas line all add it up to close to $2,000.
I love the 6 pack setups but to do something different and cheap the plates under a 2bbl can be made to look cool Ron...
http://cgi.ebay.com/ebaymotors/HOLLEY-34...0240609403&
#58560 - 05/27/08 09:03 PM Re: Cool intake manifold for a 318? [Re: 85_Ram_4speed]
mopowertim Offline
super gas
Loc: Asheboro NC
This is interesting.....
If you can't outrun it-Outlaw it! The King
#58561 - 05/28/08 08:52 AM Re: Cool intake manifold for a 318? [Re: mopowertim]
Mr.Yuck Offline
that is coool but why not just use 2 small holleys? those FoMoCo carbs ar 500 cfm each. You could use 2 450 vacuum holleys and use off the sheft linkage.
#58562 - 05/28/08 06:39 PM Re: Cool intake manifold for a 318? [Re: Mr.Yuck]
Waveraider Offline
Loc: Indianapolis
Why not buy a repro fiberglass air grabber air cleaner and make an adapter to fit the 2 bbl carb. Nobody will be able to see whats under it. Bad pic and not painted, but this should give you an idea.
Ron, are you still selling those?
'68 Satellite 'vert 440/727, Roadrunner hood and goal is to be painted by July 4th! Dreams and goals shatter like glass.
25,535 Registered Members
194,057 Topics
WIW - 1971 Hemi GTX 4 Speed
by Transman
Today at 09:39 AM
Shallow LA oil pan
by Retroboy
Today at 07:16 AM
Small Block Head ??
by Kindafast
Today at 06:59 AM
1969 Plymouth Road Runner
by tomsjack
Today at 04:56 AM
