Rallye Oil Pressure Gauge #584019
01/16/10 07:19 AM
01/16/10 07:19 AM
New Zealand
nz383man Offline OP
nz383man  Offline OP
New Zealand
This may be of some interest to anyone that has a Rallye dash.
I was interested in the calibration of the oil pressure gauge in my '70 Barracuda so I checked it out & found what you see below.
Using an air regulator on the oil pressure sender I started at zero pressure & worked my way up as far as the compressor would go.
The gauge did not register at all at 17 psi then at 18 psi the needle went up to the mark as shown below, the needle wasn't stuck it did the same thing every time I tested it.
Winding up the regulator gave the pressures indicated below but I didn't have enough air pressure to get a reading for the top mark.
Gauges will vary but it gives an idea what pressure you are running.
Re: Rallye Oil Pressure Gauge [Re: nz383man] #584020
01/16/10 08:39 AM
01/16/10 08:39 AM
N.E. England
Roppa440 Offline
super street
Roppa440  Offline
super street
N.E. England
Funny enough I was thinking of fitting an extra mechanical gauge so I could see what pressure my dash gauge was actually registering.
My needle sits about half way up so I doubt I have any problems. But I always wondered what it was actually reading.
2002 Chevrolet Corvette 5.7 LS1 2011 Alpha Romeo Giulietta Veloce 1.6 JTD Because running a Mopar in the UK is getting TOO expensive!!
Re: Rallye Oil Pressure Gauge [Re: nz383man] #584021
01/16/10 02:56 PM
01/16/10 02:56 PM
Thanks for the post. I always wonder how off my factory gauges are. I'll probably settle for a top of the line electrical. I've never had a leak (yet) on my new carpet or from any mechanical gauged vehicle I've owned but I dont like the thought of it possibly happening.
Re: Rallye Oil Pressure Gauge [Re: nz383man] #584022
05/06/11 03:48 PM
05/06/11 03:48 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Keep in mind..
The OE gauges including the oil pressure run off the 5V voltage limiter. The voltage limiter has a +/-10% tolerance, 4.5V-5.5V so the gauge will vary as the input voltage varies. Plus the sending unit has a tolerance as well, to know more precisely one should pipe in a mechanical and then cross-check..
Just my $0.02..
Re: Rallye Oil Pressure Gauge [Re: RapidRobert] #584023
05/06/11 07:13 PM
05/06/11 07:13 PM
QLD Australia
Keith Black® Offline
QLD Australia
Thanks for the post...
thanks
Darren Beale
Keith Black Racing Engines®
Re: Rallye Oil Pressure Gauge [Re: Keith Black®] #584024
05/06/11 07:36 PM
05/06/11 07:36 PM
BDW Offline
BDW  Offline
Thx, good info!
Re: Rallye Oil Pressure Gauge [Re: BDW] #584025
05/06/11 07:51 PM
05/06/11 07:51 PM
IN
ahy Offline
ahy  Offline
IN
When I first started my new engine I ran a mechanical guage along with the rally guage. Readings were similar to the OP's experience. But boy was the ralley guage slow. The mech guage would show some pressure during cranking and jump right up as soon as the engine fired. It seemed like the rally guage took 5 minutes to catch up. I don't know if they all do or if my new parts store sender is just slow?
Re: Rallye Oil Pressure Gauge [Re: ahy] #584026
05/07/11 07:49 AM
05/07/11 07:49 AM
Northern Va
Mopar73340 Offline
Mopar73340  Offline
Northern Va
Thanks for the post. As said above, the factory guages are all slow and I don't know if any 2 are the same as I have 2 E-Bodies with the rallye guages and both read different with the same basic oil psi. For anyone interested, I run an Electrical VDO oil press guage and it reacts quickly. If you didn't see the wires you wouldn't know it was electric by the speed at which it reacts.
Re: Rallye Oil Pressure Gauge [Re: ahy] #584027
05/07/11 09:01 PM
05/07/11 09:01 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
The rallye dash gauges are slow due to their design. Current from a constant voltage source flows into the gauge. The other end of the gauge goes through the sender to ground. The gauge itself is hooked to a bimetalic strip. Current flows through the strip causing it to heat up. Because of the dissimilar metals, the strip bends because one metal expands at a different rate and distance than the other. The bending metal moves the pointer, the distance dependent on the amount of current and heating of the strip.
Very, very simple and very easy to manufacture. And very slow to react. Mechanical gauges are much quicker and more accurate. They cost an order of magnitude more to manufacture so they were not used by manufacturers.
Craig
