Car won't start - No spark - No voltage at Coil
#582456
01/14/10 06:09 PM
01/14/10 06:09 PM
Posts: 157 California
dg_dodge
California
Hi guys, This past weekend my 1970 Challenger finally pulled it's first "no start" on me (after 5+ trouble free years). I went to fire it up and it just cranked and cranked .. Checked for fuel and it was fine. Took off the distributor cap and verified the rotor was turning. Checked for spark at the distributor-to-coil wire - nothing. I then swapped out the ballast resistor to a brand new one I had - still no spark. Finally, I put a multimeter to the coil and checked for voltage with the key both in the "run" position and while cranking - zero voltage both ways. I know very little about electrical problems, so I'm not sure what to try next? Could the coil or ECU (Mopar Orange) box be bad? Or something earlier upstream like the ignition switch or bulkhead piece? If so, how to test these things? The car has started so reliably in the past that it surprised me something could have just gone dead without going flakey first, but I guess anything can happen.. Any tips on what to check next would be greatly appreciated! Thanks much!
Re: Car won't start - No spark - No voltage at Coil
[Re: OzHemi]
#582464
01/14/10 07:59 PM
01/14/10 07:59 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
take in mind the yellow and red wires ilustrated on this diagrams are slightly incorrect for pre 75/76 cars.
First, yellow wire is really brown and doesn't come from starter relay, comes from ign switch
Second, red wire going to coil is brown OR blue ( depending of year )
the yellow wire coming from starter relay is JUST CORRECT for laters cars where the starter relay provides the ballast bypass instead coming directly from ign switch. Is a very diff starter relay setup
[Re: OzHemi]
#582468
01/14/10 09:31 PM
01/14/10 09:31 PM
RapidRobert
most likely bad orange box. Check that it didnt lose it's ground. then take off the wire to the coil negative primary terminal and with a jumper wire with an alligator clip on each end, clip one end of the jumper to this coil (pri-) terminal and repeatedly touch the other end alligator clip to ground repeatedly like Morse Code & see if the large coil to dist secondary wire (the dist end) held 1/4" from ground sparks (Check with key "on" and key in "start") If it (large coil wire) sparks (in both positions) that only leaves the dist pickup (not likely) and the orange box (most likely). If it doesn't spark in both positions do Nachos voltage checks to find the open (check/clean the firewall bulkheads 1st) and take all (3) wires (2 small 1 large) off of the coil & w your multimeter see if the pri and sec sides of the coil have continuity. What coil and what ballast are you using?
[Re: dg_dodge]
#582470
01/14/10 10:21 PM
01/14/10 10:21 PM
RapidRobert
I was thinking if you have a high powered coil w a lower ohm ballast that they would be more likely to fail but from your descrip that's not the case here. Take ALL wires off of the coil(-) pri terminal to do the test (your 2nd wire is most likely a tach rpm sensing wire). The bulkheads: some have a wire bail like a master cyl cover & if so take it off or flip it over & you'll see the nubs on the ends of the black bulkhead that hold them on. Depress them inward & wiggle the connector off.
[Re: strokin73cuda]
#582473
01/14/10 11:05 PM
01/14/10 11:05 PM
RapidRobert
Clean the terminals on the half you pull off w a small bristle brush and the firewall half terminals w an extra seperate male terminal or a small eyeglass screwdriver (be conservative, only need to scrape some fresh brass lines)not open them up any then yes hit it w your spray cleaner.
[Re: dg_dodge]
#582475
01/14/10 11:23 PM
01/14/10 11:23 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
Hi guys,
Thanks much!
You are giving yourself too little credit. You have found there is no power at the coil.
THAT is what is wrong. The coil needs power to operate.
If you were using a trouble shooting chart the next step would be "repair circuit, and retest".
Put the key in run, and physically follow the wire back from the coil using a test light (NOT a meter) checking at all the connectors until it lights up.
As said, bulkhead is a common spot. I've seen the connector for the ignition switch burn up too.
The reason I say not the meter, is the meter can be inaccurate in a situation like this, as it does not put load on the circuit. You can still have voltage, but not enough current capacity for anything to work. Can be great for making you chase your head up your... u know.
[Re: dave571]
#582476
01/14/10 11:49 PM
01/14/10 11:49 PM
RapidRobert
I missed that . Yes if the coil positive pri terminal isn't hot in "run and "crank" then as said trace back upstream. I am not grasping why a meter should not be used especially since he has one. Tracing backwards I think he'll find the "open" in a matter of minutes if it is on the eng side of the firewall.
[Re: RapidRobert]
#582477
01/15/10 02:15 AM
01/15/10 02:15 AM
dave571
In this situation, there is no voltage when checked with the meter, so continuing with the meter will likely find the fault. You are correct to say that the meter will work BUT The reason why a meter isn't always the best tool to find a lack of power for something is simple. Try this. Put the negative lead of a voltmeter on to the neg of a battery. Now put one hand on the positve of the battery, and the other hand on the positive of the meter. What does the meter read? Answer: Battery voltage. You have 12 volts on your hand. Will it run anything electrical? NO. The resistance of your body will not allow any current if you try to put a current load across the circuit, Yet you clearly have voltage present on the meter. If relying on meter readings, you may think the circuit is fine but it's not. An electrical device will not function here. A meter will find an open( broken wire, etc), but NOT necessarily a high resistance(corrosion in a wire, thermal damage to a connection etc..), without adding a load to the circuit at the same time. With a test light, the bulb is the load. If it lights up, you have voltage AND a cicuit that will support a load In the situation the original poster has put up, there is no voltage, so he will likely find the problem with a meter, if that is the way he goes with it. BUT A lot of the time, when "phantom" electrical problems are posted, about things not working, it's a simple error like this, that has caused most of the confusion, and made the diagnosis so difficult. You end up back at a circuit you thought was ok, but really wasn't
