small block oil pan #581931
01/14/10 03:45 AM
01/14/10 03:45 AM
TN
'84 D150 Shorty Offline OP
Pickup Man
Pickup Man
TN
Ok. I bought an oil pan for my engine. the engine is an 88. the pan is from a 92. i also bought an oil pan gasket based on a 88. to my dismay it doesnt look right... can this oil pan be used on this engine? i was hoping maybe changing to the 92 gasket would allow me to use it....
Re: small block oil pan [Re: '84 D150 Shorty] #581932
01/14/10 04:36 AM
01/14/10 04:36 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Is it a 360 or 318? did you get a gasket for a 318 and you need one for a 360 or vice versa? 360 pans are different and will not fit a 318/340/273 and also takes a different gasket.
Re: small block oil pan [Re: MoparforLife] #581933
01/14/10 12:11 PM
01/14/10 12:11 PM
Fortworth TX
mod5v Offline
mod5v  Offline
Fortworth TX
Remember that 92 is also a transition year to the magnum motor and I believe that the rear main demensions for the pan were combined fore the magnum what I'm not sure about is if the new pan is 318 or 360 main demensions. What I'm saying is u may have a magnum pan.
Re: small block oil pan [Re: '84 D150 Shorty] #581934
01/14/10 12:13 PM
01/14/10 12:13 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
Do you have a 318 or a 360?
